Aller au contenu principal
ASUS Padfone X mini Station Speaker Replacement
Ce dont vous avez besoin
  1. ASUS Padfone X mini Station Speaker Replacement, Battery: étape 1, image 1 de 1
    • Insert the plastic opening tool between the edge of the screen and the back cover.
    • Gently pry them apart. Use hands to pull them apart if necessary.
  2. ASUS Padfone X mini Station Speaker Replacement: étape 2, image 1 de 2 ASUS Padfone X mini Station Speaker Replacement: étape 2, image 2 de 2
    • Remove the three pieces of tape that secure the battery and its wires. Peel gently so you don’t damage any wires.
  3. ASUS Padfone X mini Station Speaker Replacement: étape 3, image 1 de 3 ASUS Padfone X mini Station Speaker Replacement: étape 3, image 2 de 3 ASUS Padfone X mini Station Speaker Replacement: étape 3, image 3 de 3
    • Disconnect the ribbon from the motherboard by gently pulling with your fingers.
    • Using the opening tools, pry the battery off of the adhesive.
    • Be careful not to pull the battery out right away. The ribbon cable is tucked beneath another wire.
  4. ASUS Padfone X mini Station Speaker Replacement, Speaker: étape 4, image 1 de 1
    • Use a Phillips #00 screwdriver to remove the three 2.5mm screws that secure the speaker case to the motherboard.
    • Remove all tape covering the screws before removing them.
  5. ASUS Padfone X mini Station Speaker Replacement: étape 5, image 1 de 3 ASUS Padfone X mini Station Speaker Replacement: étape 5, image 2 de 3 ASUS Padfone X mini Station Speaker Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    • Use tweezers to remove the three pieces of tape that are covering the metal.
    • Insert the metal spudger beneath the speaker case and wedge it upwards to remove speaker case from the device body.
  6. ASUS Padfone X mini Station Speaker Replacement: étape 6, image 1 de 2 ASUS Padfone X mini Station Speaker Replacement: étape 6, image 2 de 2
    • Use tweezers to detach the connecter from the motherboard.
Alexzander Pastore
Membre depuis le 10/26/18
389 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G7, Peak Fall 2018 Membre de l'équipe UMass Dartmouth, Team S2-G7, Peak Fall 2018
UMASSD-PEAK-F18S2G7
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 191
