Aller au contenu principal
ASUS Q302L Fan Replacement
Ce dont vous avez besoin
  1. ASUS Q302L Fan Replacement, Back Case: étape 1, image 1 de 1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Fan Replacement: étape 2, image 1 de 3 ASUS Q302L Fan Replacement: étape 2, image 2 de 3 ASUS Q302L Fan Replacement: étape 2, image 3 de 3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Fan Replacement: étape 3, image 1 de 1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Fan Replacement, Fan: étape 4, image 1 de 2 ASUS Q302L Fan Replacement, Fan: étape 4, image 2 de 2
    • Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
    • Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
  5. ASUS Q302L Fan Replacement: étape 5, image 1 de 3 ASUS Q302L Fan Replacement: étape 5, image 2 de 3 ASUS Q302L Fan Replacement: étape 5, image 3 de 3
    • Gently wedge two plastic prying tools on both sides of the black part of the connector.
    • Carefully pull out the connector from its socket.
  6. ASUS Q302L Fan Replacement: étape 6, image 1 de 2 ASUS Q302L Fan Replacement: étape 6, image 2 de 2
    • Once all screws and the connector are removed, you can safely pull the fan out of its place.
Kerolus Gerges
Membre depuis le 03/02/17
219 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S13-G4, Cagle Spring 2017 Membre de l'équipe USF Tampa, Team S13-G4, Cagle Spring 2017
USFT-CAGLE-S17S13G4
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 784
