Aller au contenu principal
ASUS Q302L Motherboard Replacement
Ce dont vous avez besoin
  1. ASUS Q302L Motherboard Replacement, Back Case: étape 1, image 1 de 1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Motherboard Replacement: étape 2, image 1 de 3 ASUS Q302L Motherboard Replacement: étape 2, image 2 de 3 ASUS Q302L Motherboard Replacement: étape 2, image 3 de 3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Motherboard Replacement: étape 3, image 1 de 1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Motherboard Replacement, Battery: étape 4, image 1 de 1
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Motherboard Replacement: étape 5, image 1 de 3 ASUS Q302L Motherboard Replacement: étape 5, image 2 de 3 ASUS Q302L Motherboard Replacement: étape 5, image 3 de 3
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Motherboard Replacement: étape 6, image 1 de 2 ASUS Q302L Motherboard Replacement: étape 6, image 2 de 2
    • Once the screws and connector are removed, simply pull out the battery from its place.
  7. ASUS Q302L Motherboard Replacement, Fan: étape 7, image 1 de 2 ASUS Q302L Motherboard Replacement, Fan: étape 7, image 2 de 2
    • Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
    • Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
  8. ASUS Q302L Motherboard Replacement: étape 8, image 1 de 3 ASUS Q302L Motherboard Replacement: étape 8, image 2 de 3 ASUS Q302L Motherboard Replacement: étape 8, image 3 de 3
    • Gently wedge two plastic prying tools on both sides of the black part of the connector.
    • Carefully pull out the connector from its socket.
  9. ASUS Q302L Motherboard Replacement: étape 9, image 1 de 2 ASUS Q302L Motherboard Replacement: étape 9, image 2 de 2
    • Once all screws and the connector are removed, you can safely pull the fan out of its place.
  10. ASUS Q302L Motherboard Replacement, Motherboard: étape 10, image 1 de 3 ASUS Q302L Motherboard Replacement, Motherboard: étape 10, image 2 de 3 ASUS Q302L Motherboard Replacement, Motherboard: étape 10, image 3 de 3
    • Peel back the adhered strip to expose the black and white connections.
    • Pop the connections off the fixtures.
  11. ASUS Q302L Motherboard Replacement: étape 11, image 1 de 2 ASUS Q302L Motherboard Replacement: étape 11, image 2 de 2
    • Grasp the plastic tab of each connector with your fingers.
    • Firmly pull up, releasing the connectors one at a time.
  12. ASUS Q302L Motherboard Replacement: étape 12, image 1 de 2 ASUS Q302L Motherboard Replacement: étape 12, image 2 de 2
    • As in Step 8, gently pry out both sides of the white connector and pull out the connector.
  13. ASUS Q302L Motherboard Replacement: étape 13, image 1 de 3 ASUS Q302L Motherboard Replacement: étape 13, image 2 de 3 ASUS Q302L Motherboard Replacement: étape 13, image 3 de 3
    • For each of the four marked connectors, gently insert a thin prying tool between the blue ribbon and grey tab.
    • Gently apply upward pressure evenly across the length of the tab.
    • Once the tab has snapped backwards, remove the blue ribbon.
  14. ASUS Q302L Motherboard Replacement: étape 14, image 1 de 1
    • Using the Phillips #00 screwdriver, remove the ten 4mm screws.
  15. ASUS Q302L Motherboard Replacement: étape 15, image 1 de 2 ASUS Q302L Motherboard Replacement: étape 15, image 2 de 2
    • Lift the Hinge gently up.
    • Lightly grasp the motherboard.
    • Lift the marked corner of the board first, then slide the corner of the board out from under the back corner of the case.
    • Place new thermal paste beneath the heatsink on the new motherboard.
2 autres ont terminé cette réparation.
Nicholas Lozier
Membre depuis le 04/01/19
290 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S2-G4, Harley Spring 2019 Membre de l'équipe IUPUI, Team S2-G4, Harley Spring 2019
IUPUI-HARLEY-S19S2G4
3 membres
2 tutoriels rédigés
Un commentaire
Where can I get a replacement motherboard?
Alex - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 25
Total : 1,280
