Aller au contenu principal
Introduction
This is a guide to replace the motherboard of your ASUS Q302L laptop. You may need to replace your motherboard if you determine that is the faulty component of your laptop. The first thing you’ll need is a grounding strap and grounding mat. These are to ensure that you do not damage your new motherboard or other components on your laptop while replacing the motherboard. You will also need a small Phillips #00 screwdriver, a small flat head screwdriver, and a prying tool.
  1. Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. Wedge a plastic opening tool under the rear case near the hinge. Pry around the outer edge to release the plastic clips holding the rear case to the laptop. Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. Once the cover is free from all the clips, remove the cover from the laptop.
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. Gently wedge a plastic opening tool under the connector. Pry only on the connector not the socket itself or you risk damage to the motherboard. Carefully lift the connector up away from the socket to disconnect it.
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. Once the screws and connector are removed, simply pull out the battery from its place. Once the screws and connector are removed, simply pull out the battery from its place.
    • Once the screws and connector are removed, simply pull out the battery from its place.
  7. Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan. Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
    • Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
    • Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
  8. Gently wedge two plastic prying tools on both sides of the black part of the connector. Carefully pull out the connector from its socket. Carefully pull out the connector from its socket.
    • Gently wedge two plastic prying tools on both sides of the black part of the connector.
    • Carefully pull out the connector from its socket.
  9. Once all screws and the connector are removed, you can safely pull the fan out of its place. Once all screws and the connector are removed, you can safely pull the fan out of its place.
    • Once all screws and the connector are removed, you can safely pull the fan out of its place.
  10. Peel back the adhered strip to expose the black and white connections. Pop the connections off the fixtures. Pop the connections off the fixtures.
    • Peel back the adhered strip to expose the black and white connections.
    • Pop the connections off the fixtures.
  11. Grasp the plastic tab of each connector with your fingers. Firmly pull up, releasing the connectors one at a time.
    • Grasp the plastic tab of each connector with your fingers.
    • Firmly pull up, releasing the connectors one at a time.
  12. As in Step 8, gently pry out both sides of the white connector and pull out the connector. As in Step 8, gently pry out both sides of the white connector and pull out the connector.
    • As in Step 8, gently pry out both sides of the white connector and pull out the connector.
  13. For each of the four marked connectors, gently insert a thin prying tool between the blue ribbon and grey tab. Gently apply upward pressure evenly across the length of the tab. Once the tab has snapped backwards, remove the blue ribbon.
    • For each of the four marked connectors, gently insert a thin prying tool between the blue ribbon and grey tab.
    • Gently apply upward pressure evenly across the length of the tab.
    • Once the tab has snapped backwards, remove the blue ribbon.
  14. Using the Phillips #00 screwdriver, remove the ten 4mm screws.
    • Using the Phillips #00 screwdriver, remove the ten 4mm screws.
  15. Lift the Hinge gently up. Lightly grasp the motherboard.
    • Lift the Hinge gently up.
    • Lightly grasp the motherboard.
    • Lift the marked corner of the board first, then slide the corner of the board out from under the back corner of the case.
    • Place new thermal paste beneath the heatsink on the new motherboard.
2 autres ont terminé cette réparation.
Nicholas Lozier
Membre depuis le 01/04/2019
290 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S2-G4, Harley Spring 2019 Membre de l'équipe IUPUI, Team S2-G4, Harley Spring 2019
IUPUI-HARLEY-S19S2G4
3 membres
2 tutoriels rédigés
Where can I get a replacement motherboard?
Alex - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 23
Total : 709
