Aller au contenu principal
ASUS Q324UA-BHI7T17 Motherboard Replacement
Ce dont vous avez besoin
  1. ASUS Q324UA-BHI7T17 Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Remove all 10 Phillips screws on the backplate.
    • All 10 screws are 0.55 inches and 20 mm in diameter.
  2. ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 2, image 1 de 2 ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 2, image 2 de 2
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 3, image 1 de 1
    • Locate the battery near the bottom.
  4. ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Next, lift up the battery connector from the laptop in the upper left side of the battery, using tweezers or spudger.
    • Make sure to complete this step with caution, because if the battery is not unplugged, the motherboard may shock you.
  5. ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 5, image 1 de 2 ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 5, image 2 de 2
    • Remove the six screws holding in the battery with a Phillips #0 screwdriver.
    • Once battery is lifted out and removed, proper dispose of the old battery.
    • Each screw is 0.5 cm in length and 0.5 cm in diameter.
  6. ASUS Q324UA-BHI7T17 Motherboard Replacement, CPU Fan: étape 6, image 1 de 2 ASUS Q324UA-BHI7T17 Motherboard Replacement, CPU Fan: étape 6, image 2 de 2
    • Using a Phillips #0 screwdriver remove the six screws holding the CPU Fan and Heatsink in place.
    • All six screws are 0.4 cm in length and have a 0.5 cm head diameter.
  7. ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 7, image 1 de 2 ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 7, image 2 de 2
    J'achète
    • Next, carefully remove the sliding connector that connect the CPU Fan and the laptop together using the tweezers.
  8. ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 8, image 1 de 1
    • Remove the CPU Fan and Heatsink by simply lifting upwards.
  9. ASUS Q324UA-BHI7T17 Motherboard Replacement, Motherboard: étape 9, image 1 de 2 ASUS Q324UA-BHI7T17 Motherboard Replacement, Motherboard: étape 9, image 2 de 2
    • Locate the two connectors that are located near the top of the motherboard.
    • Simply lift the two connectors up and they should pop out easily.
  10. ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 10, image 1 de 2 ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 10, image 2 de 2
    J'achète
    • Locate all 5 ribbon cables that are connected to the motherboard.
    • Using tweezers lift the black component up therefore allowing the ribbon cable to be released and taken out.
  11. ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 11, image 1 de 2 ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 11, image 2 de 2
    • Locate the single sliding connector that is attached to the motherboard.
    • Using tweezers slightly remove the sliding connector from the motherboard.
  12. ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 12, image 1 de 3 ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 12, image 2 de 3 ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 12, image 3 de 3
    • There are two chips that are attached to the motherboard. One is a square wifi card and one is a rectangular m.2 ssd, locate them on the motherboard.
    • Remove the two screws holding the chips in place on the mother board.
    • The screw for the rectangle chip is 0.5cm in length and 0.5cm in head diameter. While the square chip screw has a 0.3 cm length and 0.5 cm head diameter.
    • Both chips now can be removed by simply sliding them out of their connectors.
  13. ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 13, image 1 de 2 ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 13, image 2 de 2
    • Locate the 3 screws near the top of the motherboard holding the motherboard in place.
    • Using a Phillips head #0 screw driver remove each screw driver.
    • The screw all the way to the right is 0.5cm in length and 0.4cm in head diameter. The screw all the way to the left is 0.6 cm in length and 0.4cm in head diameter. The screw in the middle is 0.3cm in length and 0.5 cm in head diameter.
  14. ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 14, image 1 de 3 ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 14, image 2 de 3 ASUS Q324UA-BHI7T17 Motherboard Replacement: étape 14, image 3 de 3
    • Locate the final screw that holds the motherboard in place, on the left side of the motherboard near the middle.
    • Using a Phillips head #0 screwdriver remove the screw. The motherboard should easily pop out and from there properly dispose of the mother board.
    • The screw is 0.3cm in length and 0.5 cm in head diameter.
Scott Santiago
Membre depuis le 10/17/17
534 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G1, Simcock Fall 2017 Membre de l'équipe UMass Dartmouth, Team S1-G1, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 927
