Aller au contenu principal
ASUS Q400A-BHI7N03 Optical Drive Replacement
Ce dont vous avez besoin
  1. ASUS Q400A-BHI7N03 Optical Drive Replacement, Battery: étape 1, image 1 de 1
    • Turn off the laptop.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop over so that it is upside down.
    • The slightly raised area is the battery.
    • Orient the laptop so that the battery is away from you.
  2. ASUS Q400A-BHI7N03 Optical Drive Replacement: étape 2, image 1 de 1
    • In the top right corner, push the tab to the right to the unlocked position.
  3. ASUS Q400A-BHI7N03 Optical Drive Replacement: étape 3, image 1 de 2 ASUS Q400A-BHI7N03 Optical Drive Replacement: étape 3, image 2 de 2
    • Find the tab in the top left corner. With one finger, pull the tab to the left to the unlocked position.
    • While holding this tab in the unlocked position, gently pull the battery away from you.
  4. ASUS Q400A-BHI7N03 Optical Drive Replacement, Optical Drive: étape 4, image 1 de 1
    • Locate and remove the 8mm PH0 screw near the middle of the laptop.
  5. ASUS Q400A-BHI7N03 Optical Drive Replacement: étape 5, image 1 de 2 ASUS Q400A-BHI7N03 Optical Drive Replacement: étape 5, image 2 de 2
    • Use a metal opening tool to remove the L-shaped, plastic cover.
    • To avoid breaking the plastic, alternate the sides where you pry.
  6. ASUS Q400A-BHI7N03 Optical Drive Replacement: étape 6, image 1 de 2 ASUS Q400A-BHI7N03 Optical Drive Replacement: étape 6, image 2 de 2
    • On the left side of the section, there is a metal tab. Using a metal opening tool, push the tab as far as possible to the left.
    • Only push on the metal tab so you do not damage the surrounding plastic.
    • Once the optical drive is sticking out of the left side of the laptop, slide it smoothly out of its slot.
Matthew Gold
Membre depuis le 01/19/17
401 Réputation
4 tutoriels rédigés
Équipe
UC Davis, Team 1-4, Rodger Winter 2017 Membre de l'équipe UC Davis, Team 1-4, Rodger Winter 2017
UCD-RODGER-W17S1G4
5 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 15
Total : 517
