Aller au contenu principal
ASUS Q400A-BHI7N03 Screen Replacement
Ce dont vous avez besoin
  1. ASUS Q400A-BHI7N03 Screen Replacement, Screen: étape 1, image 1 de 1
    • Flip the laptop on its back side with the battery facing toward you.
    • Slide the tabs with lock/unlock symbol, to the unlock position.
    • Grabbing the top edge of the battery, lift upward to relieve the battery from its slot.
  2. ASUS Q400A-BHI7N03 Screen Replacement: étape 2, image 1 de 1
    • Lift the two black plastic circles off the screen using the plastic spudger.
    • Unscrew the two 8mm Phillips #0 screws.
  3. ASUS Q400A-BHI7N03 Screen Replacement: étape 3, image 1 de 1
    • Pry the front edges of the screen using the spudger.
  4. ASUS Q400A-BHI7N03 Screen Replacement: étape 4, image 1 de 1
    • Remove the four black 8mm Phillips #0 screws and set them aside.
  5. ASUS Q400A-BHI7N03 Screen Replacement: étape 5, image 1 de 1
    • Pry the LCD from the front frame.
  6. ASUS Q400A-BHI7N03 Screen Replacement: étape 6, image 1 de 1
    • Pull the gold ribbon cable to disconnect the screen from the laptop.
3 autres ont terminé cette réparation.
Wan Ahmad Aiman
Membre depuis le 10/31/18
403 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G3, Harley Fall 2018 Membre de l'équipe IUPUI, Team S1-G3, Harley Fall 2018
IUPUI-HARLEY-F18S1G3
3 membres
2 tutoriels rédigés
Un commentaire
Can you tell me what is the part number and description for the display, I need to order one to replace mi ASUS broken screen. Thanks in advance...!!!
Daniel Ventura Avalos - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 569
