Introduction
When replacing a hard drive in a laptop, it's important to assess the specific issues you're facing, consider your budget and requirements, and determine whether a simple upgrade or a transition to a different storage technology (like an SSD) would be most beneficial. Additionally, backing up important data before any hardware changes is crucial to prevent data loss.
Ce dont vous avez besoin
Remove ten 2 mm screws using a Phillips #0 screwdriver.
Remove the screw in the center using a T4 Torx screwdriver.
Use an iFixit opening tool to pry open the back panel.
Disconnect the white ribbon cable from the connection lever using a Jimmy.
