Aller au contenu principal
ASUS R554L Battery Replacement
Ce dont vous avez besoin
  1. ASUS R554L Battery Replacement, Battery: étape 1, image 1 de 1
    • Flip the laptop so the bottom is facing upward.
    • Remove ten screws using a Phillips #0 screwdriver.
  2. ASUS R554L Battery Replacement: étape 2, image 1 de 3 ASUS R554L Battery Replacement: étape 2, image 2 de 3 ASUS R554L Battery Replacement: étape 2, image 3 de 3
    • Using your fingertips, carefully pull the backplate in an upright direction.
    • Continue along the edges until the backplate is fully removed.
    • It's normal to hear cracking while pulling up on the plate.
  3. ASUS R554L Battery Replacement: étape 3, image 1 de 3 ASUS R554L Battery Replacement: étape 3, image 2 de 3 ASUS R554L Battery Replacement: étape 3, image 3 de 3
    • Remove the four screws from the battery using a Phillips #0 screwdriver.
    • Pull up on the cable connected to the motherboard to remove.
    • Remove the battery from the bay.
  4. ASUS R554L Battery Replacement: étape 4, image 1 de 3 ASUS R554L Battery Replacement: étape 4, image 2 de 3 ASUS R554L Battery Replacement: étape 4, image 3 de 3
    • Place the new battery in the bay.
    • Install the battery cable to the motherboard, applying pressure in a downward direction.
    • Screws the screws back in using a Phillips #0 screwdriver.
  5. ASUS R554L Battery Replacement: étape 5, image 1 de 3 ASUS R554L Battery Replacement: étape 5, image 2 de 3 ASUS R554L Battery Replacement: étape 5, image 3 de 3
    • Align the backplate.
    • Starting with the upper right corner, apply pressure in a downward angle.
    • Repeat the process around the backplate until it's fully secure.
  6. ASUS R554L Battery Replacement: étape 6, image 1 de 2 ASUS R554L Battery Replacement: étape 6, image 2 de 2
    • Screw the backplate screws back in using a Phillips #0 screwdriver.
Once the new battery is installed, leave the charger connected to the laptop over night to ensure the battery is holding a charge
Joshua Chavez
Membre depuis le 01/31/22
160 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 4-49, Briggs Spring 2022 Membre de l'équipe CSU Los Angeles, Team 4-49, Briggs Spring 2022
CSULA-BRIGGS-S22S4G49
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 39
30 derniers jours : 229
Total : 4,589
