Introduction
In this guide, we will replace the screen of the Asus ROG G750JW-RS72-CB.
Pièces
Aucune pièce nécessaire.
Make sure you completely power down the computer before beginning this process.
  • Make sure you completely power down the computer before beginning this process.
  • With your finger, push this slide to the right. The battery should pop out of place.
Ajouter un commentaire
Pull the battery out of its place gently.
  • Pull the battery out of its place gently.
  • Lift up the flap using a plastic opening tool.
  • Hold the flap back with your finger.
  • Unscrew the 5.2mm screw underneath the flap.
  • Once the screw is out, pull on the plastic tab to pull off the plastic cover.
  • Unscrew the 5.2mm screws holding the hard drive in place.
  • Gently pull the rubber hard drive mount to the side.
  • Pull the drive out.
  • Remove the 8.5mm screws holding the bottom half of the laptop together.
  • Take a metal separater and gently pry open the back end of the laptop halves.
  • Remove the connector connecting the screen and the motherboard
  • Unscrew the 6.8mm screws holding the hinges of the screen to the bottom half of the computer.
  • Detach the screen from the hinges of the laptop.
  • Be careful not to damage the connecting wires when detaching the screen.
  • Use a metal separator to carefully separate the bottom half of the laptop.
  • Gently unplug the cables connecting the screen to the motherboard.
  • The display assembly can now be freely separated.
Sully Chen
Membre depuis le 22/01/2018
276 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S11-G5, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S11-G5, Banghart Winter 2018
CPSU-BANGHART-W18S11G5
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 31
Total : 104
