Aller au contenu principal
ASUS ROG G750JW-RS72-CB Hard Drive Replacement
Ce dont vous avez besoin
  1. ASUS ROG G750JW-RS72-CB Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Make sure you completely power down the computer before beginning this process.
    • With your finger, push this slide to the right. The battery should pop out of place.
  2. ASUS ROG G750JW-RS72-CB Hard Drive Replacement: étape 2, image 1 de 1
    • Pull the battery out of its place gently.
  3. ASUS ROG G750JW-RS72-CB Hard Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • Lift up the flap using a plastic opening tool.
    • Hold the flap back with your finger.
  4. ASUS ROG G750JW-RS72-CB Hard Drive Replacement: étape 4, image 1 de 1
    • Unscrew the 5.2mm screw underneath the flap.
  5. ASUS ROG G750JW-RS72-CB Hard Drive Replacement: étape 5, image 1 de 2 ASUS ROG G750JW-RS72-CB Hard Drive Replacement: étape 5, image 2 de 2
    • Once the screw is out, pull on the plastic tab to pull off the plastic cover.
  6. ASUS ROG G750JW-RS72-CB Hard Drive Replacement: étape 6, image 1 de 3 ASUS ROG G750JW-RS72-CB Hard Drive Replacement: étape 6, image 2 de 3 ASUS ROG G750JW-RS72-CB Hard Drive Replacement: étape 6, image 3 de 3
    • Unscrew the 5.2mm screws holding the hard drive in place.
    • Gently pull the rubber hard drive mount to the side.
    • Pull the drive out.
Joseph Rockwell
Membre depuis le 01/22/18
243 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S11-G5, Banghart Winter 2018 Membre de l'équipe Cal Poly, Team S11-G5, Banghart Winter 2018
CPSU-BANGHART-W18S11G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 10
Total : 706
