Aller au contenu principal
ASUS ROG Strix GL503VD-DB71 Display Replacement
Ce dont vous avez besoin
  1. ASUS ROG Strix GL503VD-DB71 Display Replacement, Display: étape 1, image 1 de 3 ASUS ROG Strix GL503VD-DB71 Display Replacement, Display: étape 1, image 2 de 3 ASUS ROG Strix GL503VD-DB71 Display Replacement, Display: étape 1, image 3 de 3
    • Open the laptop where the screen is now showing
    • Find the two stickers on the bottom of the display and remove them
    • Use the Phillips #1 screwdriver to take out the two screws at the bottom of the display.
  2. ASUS ROG Strix GL503VD-DB71 Display Replacement: étape 2, image 1 de 3 ASUS ROG Strix GL503VD-DB71 Display Replacement: étape 2, image 2 de 3 ASUS ROG Strix GL503VD-DB71 Display Replacement: étape 2, image 3 de 3
    • Use the plastic opening tool to remove the plastic bezel around the screen.
    • Pry the remainder of the cover off of the hinges at the bottom of the sides of the display.
  3. ASUS ROG Strix GL503VD-DB71 Display Replacement: étape 3, image 1 de 3 ASUS ROG Strix GL503VD-DB71 Display Replacement: étape 3, image 2 de 3 ASUS ROG Strix GL503VD-DB71 Display Replacement: étape 3, image 3 de 3
    • Using a Phillips #1 screwdriver, remove the four screws at the top and bottom of the display.
    • Unplug the display from the rest of the laptop at the back bottom of the display.
    • Remove the display.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 1,156
