Aller au contenu principal
ASUS ROG Strix GL503VD-DB71 Fan Replacement
Ce dont vous avez besoin
  1. ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: étape 1, image 1 de 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: étape 1, image 2 de 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: étape 1, image 3 de 3
    • Flip the laptop over so that the bottom is facing up.
    • Remove the ten screws around the edges and in the center of the back case with a Phillips #1 screwdriver.
  2. ASUS ROG Strix GL503VD-DB71 Fan Replacement: étape 2, image 1 de 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: étape 2, image 2 de 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: étape 2, image 3 de 3
    • Pry up the triangular service cover with a plastic opening tool.
    • Remove the single Phillips #1 screw beneath the cover.
    • Pry up the remainder of the back cover with a plastic opening tool and remove the back cover.
  3. ASUS ROG Strix GL503VD-DB71 Fan Replacement: étape 3, image 1 de 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: étape 3, image 2 de 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: étape 3, image 3 de 3
    • Remove the four screws from the fans with a Phillips #1 screwdriver.
    • Unplug each of the fan connectors from the motherboard.
    • Remove each fan by lifting it from the case.
2 commentaires
Hi! I have a GL503VD-EB72 and my fans look ever so slightly different. Trying to replace one right now but I’m seeing a lot of variety in what’s available on eBay and amazon…How can I tell if my fans are 5V or 12V?
Kirsten M - Réponse
WTF i can find a 12 V for my GL503V
mrparisalexandre - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 38
Total : 4,516
