Aller au contenu principal
ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement
Ce dont vous avez besoin
  1. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement, M.2 Solid State Drive: étape 1, image 1 de 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement, M.2 Solid State Drive: étape 1, image 2 de 2
    • Completely turn off the laptop, lay it on a flat surface, and turn it over.
  2. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 2, image 1 de 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 2, image 2 de 2
    • Using a plastic pry tool, pry off the rubber tab to reveal the screw underneath.
  3. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 3, image 1 de 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 3, image 2 de 2
    • Using a Phillips #0 screwdriver, unscrew the one 2 mm screw that is holding down the compartment cover on the bottom of the laptop.
  4. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 4, image 1 de 3 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 4, image 2 de 3 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 4, image 3 de 3
    • With a plastic pry tool, carefully pry open the cover on the bottom of the laptop starting where the screw was located.
    • Once part of the cover is popped off, slide your pry tool around the edge of the entire cover until all the connectors unsnap.
  5. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 5, image 1 de 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 5, image 2 de 2
    • Locate the M.2 SSD and with a Phillips #0 screwdriver unscrew the 2.5 mm screw holding it down.
  6. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 6, image 1 de 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 6, image 2 de 2
    • With your hand, lift up the M.2 SSD and carefully pull it out of the connector slot making sure not to apply to much pressure.
  7. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 7, image 1 de 1
    • Take your new M.2 SSD and slide it back into the connector slot face up until it is fully in.
    • Some connection pads on M.2 SSDs are very fragile and can be broken easily.
  8. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 8, image 1 de 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 8, image 2 de 2
    • Take the 2.5 mm screw that was holding down the M.2 SSD and with a Phillips #0 screwdriver screw it back into the slot to hold down the new M.2 SSD.
  9. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 9, image 1 de 1
    • Take the bottom panel and align it so the shape fits to the opening.
    • Slide the left side of the cover back into the slot first so that the two extrusions fit into their openings.
  10. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 10, image 1 de 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 10, image 2 de 2
    • Carefully press down around all the sides of the bottom cover until all the connectors snap back into place.
  11. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 11, image 1 de 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 11, image 2 de 2
    • Using a Phillips #0 screwdriver, take the 2 mm screw that was holding down the cover and screw it back into the opening on the cover.
  12. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: étape 12, image 1 de 1
    • Place the rubber tab back into its slot with the sticky side down.
Ligne d'arrivée
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 18
30 derniers jours : 47
Total : 6,601
