Introduction
If your screen is glitching or the screen goes in and out, it might be a loose display connector. Use this guide if you need to check to see if your display connector is loose.
Ce dont vous avez besoin
Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
Once the back has been removed, locate this connection cable.
Check to see if the connector is in the pin slot; if not, locate the connector.
Presque terminé !
