Aller au contenu principal
ASUS ROG Zephyrus M15GU205L Fan Cleaning
Ce dont vous avez besoin
  1. ASUS ROG Zephyrus M15GU205L Fan Cleaning, Battery: étape 1, image 1 de 2 ASUS ROG Zephyrus M15GU205L Fan Cleaning, Battery: étape 1, image 2 de 2
    • Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
  2. ASUS ROG Zephyrus M15GU205L Fan Cleaning: étape 2, image 1 de 2 ASUS ROG Zephyrus M15GU205L Fan Cleaning: étape 2, image 2 de 2
    • Use a plastic opening tool to separate the back cover from the laptop.
    • It is recommended that you separate the laptop cover from the side and run the tool along the edge of the cover to open it.
    • Be careful not to damage the cover when removing it from the laptop.
  3. ASUS ROG Zephyrus M15GU205L Fan Cleaning: étape 3, image 1 de 1
    • Remove six 4.8 mm screws that secure the battery using a Phillips #00 screwdriver.
  4. ASUS ROG Zephyrus M15GU205L Fan Cleaning: étape 4, image 1 de 2 ASUS ROG Zephyrus M15GU205L Fan Cleaning: étape 4, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Disconnect the 8-pin battery that secures the battery to the motherboard.
    • Use the nylon tipped reverse tweezers to squeeze the edges, then pull out the connector.
  5. ASUS ROG Zephyrus M15GU205L Fan Cleaning: étape 5, image 1 de 1
    • Remove the battery from the computer.
  6. ASUS ROG Zephyrus M15GU205L Fan Cleaning, ASUS ROG Zephyrus M15GU205L Fan Cleaning: étape 6, image 1 de 2 ASUS ROG Zephyrus M15GU205L Fan Cleaning, ASUS ROG Zephyrus M15GU205L Fan Cleaning: étape 6, image 2 de 2
    Microfiber Cleaning Cloths
    $3.99
    J'achète
    • Use the microfiber cloth to wipe any surface dust off the fan fins.
    • Wipe lightly as to not push any of the dust inside.
    • Wiping off the dust is optional.
  7. ASUS ROG Zephyrus M15GU205L Fan Cleaning: étape 7, image 1 de 2 ASUS ROG Zephyrus M15GU205L Fan Cleaning: étape 7, image 2 de 2
    • Use the compressed air to blow out the dust from the fan.
    • Use the information on how to correctly use the product you selected.
    • Use the air until you see the results you are comfortable with.
eli2243977
Membre depuis le 09/07/23
281 Réputation
2 tutoriels rédigés
Équipe
Gateway, Team 69-69, Gonzalez Fall 2023 Membre de l'équipe Gateway, Team 69-69, Gonzalez Fall 2023
GCC-GONZALEZ-F23S69G69
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 32
30 derniers jours : 110
Total : 436
