Aller au contenu principal
ASUS TUF Gaming FX505DY Back Case Replacement
Ce dont vous avez besoin
  1. ASUS TUF Gaming FX505DY Back Case Replacement, Back Case: étape 1, image 1 de 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Back Case Replacement: étape 2, image 1 de 2 ASUS TUF Gaming FX505DY Back Case Replacement: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Back Case Replacement: étape 3, image 1 de 2 ASUS TUF Gaming FX505DY Back Case Replacement: étape 3, image 2 de 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Back Case Replacement: étape 4, image 1 de 2 ASUS TUF Gaming FX505DY Back Case Replacement: étape 4, image 2 de 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
Benyamin Claxton
Membre depuis le 03/27/22
800 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-4, Mellen Spring 2022 Membre de l'équipe UMass Dartmouth, Team 2-4, Mellen Spring 2022
UMASSD-MELLEN-S22S2G4
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 72
Total : 1,065
