Aller au contenu principal
ASUS TUF Gaming FX505DY Battery Replacement
Ce dont vous avez besoin
  1. ASUS TUF Gaming FX505DY Battery Replacement, Back Case: étape 1, image 1 de 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY Battery Replacement: étape 2, image 1 de 2 ASUS TUF Gaming FX505DY Battery Replacement: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY Battery Replacement: étape 3, image 1 de 2 ASUS TUF Gaming FX505DY Battery Replacement: étape 3, image 2 de 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY Battery Replacement: étape 4, image 1 de 2 ASUS TUF Gaming FX505DY Battery Replacement: étape 4, image 2 de 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY Battery Replacement, Battery: étape 5, image 1 de 3 ASUS TUF Gaming FX505DY Battery Replacement, Battery: étape 5, image 2 de 3 ASUS TUF Gaming FX505DY Battery Replacement, Battery: étape 5, image 3 de 3
    • Using an ESD-safe spudger, disconnect the battery connector by pulling the plug away from its port.
  6. ASUS TUF Gaming FX505DY Battery Replacement: étape 6, image 1 de 2 ASUS TUF Gaming FX505DY Battery Replacement: étape 6, image 2 de 2
    • Remove the 6 mm screw holding the battery in place using a Phillips #1 screwdriver.
    • Avoid cutting, puncturing, or otherwise damaging the battery. Li-ion batteries can combust or explode if damaged.
  7. ASUS TUF Gaming FX505DY Battery Replacement: étape 7, image 1 de 3 ASUS TUF Gaming FX505DY Battery Replacement: étape 7, image 2 de 3 ASUS TUF Gaming FX505DY Battery Replacement: étape 7, image 3 de 3
    • Use a spudger to pry the retaining pin into the closed position to allow the battery frame to be removed.
  8. ASUS TUF Gaming FX505DY Battery Replacement: étape 8, image 1 de 1
    • Lift the battery up out of the computer.
Ronald Brodeur
Membre depuis le 03/30/22
109 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 2-4, Mellen Spring 2022 Membre de l'équipe UMass Dartmouth, Team 2-4, Mellen Spring 2022
UMASSD-MELLEN-S22S2G4
4 membres
8 tutoriels rédigés
Un commentaire
What Is the serial number of the battery ?
Hector Garcia - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 16
30 derniers jours : 66
Total : 2,360
