Aller au contenu principal
ASUS TUF Gaming FX505DY CMOS Battery Replacement
Ce dont vous avez besoin
  1. ASUS TUF Gaming FX505DY CMOS Battery  Replacement, Back Case: étape 1, image 1 de 1
    • Turn off the laptop.
    • Disconnect the charging cable.
    • Failure to disconnect the charging cable and power down the computer could result in personal or property damage.
    • Flip the laptop so the back is facing up.
  2. ASUS TUF Gaming FX505DY CMOS Battery  Replacement: étape 2, image 1 de 2 ASUS TUF Gaming FX505DY CMOS Battery  Replacement: étape 2, image 2 de 2
    • Use a Phillips #1 screwdriver to remove the five 6 mm screws that secure the back panel.
    • Use the same screwdriver to remove the six 13 mm screws securing the back panel.
  3. ASUS TUF Gaming FX505DY CMOS Battery  Replacement: étape 3, image 1 de 2 ASUS TUF Gaming FX505DY CMOS Battery  Replacement: étape 3, image 2 de 2
    • Insert the plastic opening tool at a corner and pry up along the edges, leaving the back side with the hinges for last.
    • Do not insert the opening tool too far into the laptop to avoid damaging internal components.
  4. ASUS TUF Gaming FX505DY CMOS Battery  Replacement: étape 4, image 1 de 2 ASUS TUF Gaming FX505DY CMOS Battery  Replacement: étape 4, image 2 de 2
    • Gently lift up the back panel to release any remaining clips on the side with the hinges and remove the panel.
  5. ASUS TUF Gaming FX505DY CMOS Battery  Replacement, CMOS Battery: étape 5, image 1 de 2 ASUS TUF Gaming FX505DY CMOS Battery  Replacement, CMOS Battery: étape 5, image 2 de 2
    • Gently insert the narrow end of a spudger beneath the CMOS battery and push in, raising the battery.
  6. ASUS TUF Gaming FX505DY CMOS Battery  Replacement: étape 6, image 1 de 1
    • Remove the battery from its socket at an angle.
Carter Owen
Membre depuis le 03/30/22
169 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-4, Mellen Spring 2022 Membre de l'équipe UMass Dartmouth, Team 2-4, Mellen Spring 2022
UMASSD-MELLEN-S22S2G4
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 33
30 derniers jours : 134
Total : 3,554
