Aller au contenu principal
ASUS Transformer Book T100 Chi Screen Replacement
Ce dont vous avez besoin
  1. ASUS Transformer Book T100 Chi Screen Replacement, Pry Up the Screen: étape 1, image 1 de 3 ASUS Transformer Book T100 Chi Screen Replacement, Pry Up the Screen: étape 1, image 2 de 3 ASUS Transformer Book T100 Chi Screen Replacement, Pry Up the Screen: étape 1, image 3 de 3
    • I originally tried using an iOpener to heat the glass and melt the adhesive underneath, but finally had much better luck using a hair dryer about half an inch from the surface for 30 seconds at a time. If you expect significant screen cracking, you might consider covering the entire front with packing tape, as small slivers can fly upward.
    • As you may see in later pictures, it is probably best to start at a weak spot in the lower right corner of the screen, diagonal from the on/off button. Proceed around the screen, inserting and slowly moving picks or cards, but be careful along the top edge not to go too far to the left of the front camera, as I did.
    • In the third photo, you see the obstacles for breaking the adhesive along the top edge. From the rear-facing camera (square) to the front-facing camera (circle) there are three cables connected to the front assembly. You can also see where I dinged the LCD cable. The connector eventually just broke off from the trauma.
  2. ASUS Transformer Book T100 Chi Screen Replacement, Remove the Cables: étape 2, image 1 de 1
    • The cables pull straight out of the connectors, towards the top edge of the device. Here you can see the obstacles to avoid: the cables and connectors, and the rear-facing camera (which can stick up a bit). The WiFi antennas on the sides do not interfere.
    • Notice the circled screw, which prevents there from being much adhesive, making for a good starting place for prying up the screen.
    • From here, reassembly is essentially the opposite. I'm uncertain if you will need any additional adhesive to secure the replacement LCD / digitizer.
3 autres ont terminé cette réparation.
Jim Peterson
Membre depuis le 10/17/17
216 Réputation
1 tutoriel rédigé
2 commentaires
Just a word of caution. This tablet is a nightmare to remove the screen from in one piece. If you are looking to replace the battery or resolder a USB port or similar, be prepared to fork out for a new LCD assembly too. They are sooo paper thin and adhered so well, that even the most patient and skilled tech would find removed the screen intact near impossible. I have personally replaced many a screen and touch panel on various devices. This is BY FAR the worse tablet to work on. Do yourself a favour and sell it on eBay for someone else to do.
Craig Corner - Réponse
Thanks for the instructions, I have replace the screen on an older T100 where the back pops off. Tried that on the CHI model and destroyed the screen :-(. I wish I could have seen this post first …..
mitchell Galper - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 25
Total : 4,325
