Aller au contenu principal
ASUS U52F-BBG6 Keyboard Replacement
Ce dont vous avez besoin
  1. ASUS U52F-BBG6 Keyboard Replacement, Back Cover: étape 1, image 1 de 2 ASUS U52F-BBG6 Keyboard Replacement, Back Cover: étape 1, image 2 de 2
    • Flip the laptop over to the back.
    • Slide the right latch to unlock, then simultaneously slide the left latch outward while pulling the battery out.
  2. ASUS U52F-BBG6 Keyboard Replacement: étape 2, image 1 de 3 ASUS U52F-BBG6 Keyboard Replacement: étape 2, image 2 de 3 ASUS U52F-BBG6 Keyboard Replacement: étape 2, image 3 de 3
    • Unscrew all twelve 3mm Phillips screws with the J1 screwdriver.
    • Unscrew two 3mm Phillips screws on the black panel using the PH0 screwdriver.
    • Lift the black panel upward by inserting your fingernail in the space provided.
  3. ASUS U52F-BBG6 Keyboard Replacement: étape 3, image 1 de 3 ASUS U52F-BBG6 Keyboard Replacement: étape 3, image 2 de 3 ASUS U52F-BBG6 Keyboard Replacement: étape 3, image 3 de 3
    • In the RAM and hard drive compartment, unscrew the four 3mm Phillips screws using the J1 screwdriver.
    • Gently pull out the hard drive.
  4. ASUS U52F-BBG6 Keyboard Replacement: étape 4, image 1 de 2 ASUS U52F-BBG6 Keyboard Replacement: étape 4, image 2 de 2
    • Unscrew six 3mm Phillips screws in the RAM and hard drive compartment with the J1 screwdriver.
  5. ASUS U52F-BBG6 Keyboard Replacement: étape 5, image 1 de 1
    • Pull the CD drive outward with your left hand.
  6. ASUS U52F-BBG6 Keyboard Replacement: étape 6, image 1 de 2 ASUS U52F-BBG6 Keyboard Replacement: étape 6, image 2 de 2
    • Insert and gently twist the flat metal spudger between the keyboard assembly and the bottom plastic cover so that a small seam is opened.
    • Put in the metal spudger in the seam to hold its place while twisting and levering the flat metal spudger along the whole keyboard.
    • Be careful not to hit any of the internals with the metal spudger. The regular black nylon spudger should be used whenever possible, especially around batteries or sensitive internal components.
    • You will need add a lot of pressure to open the laptop. Expect to hear snaps as the clips holding the two pieces are released.
    • Slowly pry off the back
  7. ASUS U52F-BBG6 Keyboard Replacement, Keyboard: étape 7, image 1 de 2 ASUS U52F-BBG6 Keyboard Replacement, Keyboard: étape 7, image 2 de 2
    • Unlatch the clip attaching the white flattened flexible cord with a blue tip to the circuit board with your thumb.
    • Pull out the white flattened cord.
  8. ASUS U52F-BBG6 Keyboard Replacement: étape 8, image 1 de 1
    • Pull back yellow tape attaching the metal colored flexible flattened cord to the circuit board.
    • Lift up the latch at the end of the cord.
    • Pull out the cord to release the keyboard.
Ashley DeHuff
Membre depuis le 09/15/16
852 Réputation
8 tutoriels rédigés
Équipe
CSU Fullerton, Team 1-3, Bruce Fall 2016 Membre de l'équipe CSU Fullerton, Team 1-3, Bruce Fall 2016
CSUF-BRUCE-F16S1G3
4 membres
9 tutoriels rédigés
Un commentaire
How do you remove the keyboard from the palm rest is what I'd like to know...what a goofy design
love4talent - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 759
