Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
Need to access the internals of your ASUS VG248? Here's a guide that shows how to remove the frame and open the display.
  1. Before you begin, lay the monitor face down on a smooth, clean surface. Four rubbery covers hide four screws in the rear of the monitor.
    • Before you begin, lay the monitor face down on a smooth, clean surface.
    • Four rubbery covers hide four screws in the rear of the monitor.
    • Pry out the plastic covers with a stiff pointed tool, like a metal spudger.
  2. Remove the four 13.4 mm Philips #1 screws securing the monitor stand.
    • Remove the four 13.4 mm Philips #1 screws securing the monitor stand.
  3. Remove the stand from the display. Remove the stand from the display.
    • Remove the stand from the display.
  4. The display bezel is held to the rear case by plastic clips that can be released by pulling straight up on the bezel. Rather than use any prying tools that could damage the LCD, it's best to just pull with your fingers. A thin cloth will both protect your fingertips and prevent you from smudging the LCD.
    • The display bezel is held to the rear case by plastic clips that can be released by pulling straight up on the bezel.
    • Rather than use any prying tools that could damage the LCD, it's best to just pull with your fingers. A thin cloth will both protect your fingertips and prevent you from smudging the LCD.
    • Lay the cloth over one of the long edges of the display.
    • Grip the side of the bezel through the cloth and lift straight up. A few clips in the center will pop free.
    • Be careful to pull straight up, and not pry against the display. Pushing down on the display could damage it.
  5. Repeat the procedure around the display, lifting up the center of the next side. Repeat the procedure around the display, lifting up the center of the next side.
    • Repeat the procedure around the display, lifting up the center of the next side.
  6. Move around to the other long side and lift up on the center of the bezel. Move around to the other long side and lift up on the center of the bezel.
    • Move around to the other long side and lift up on the center of the bezel.
  7. Grip the center of the final side and lift the bezel away from the rear case. Grip the center of the final side and lift the bezel away from the rear case.
    • Grip the center of the final side and lift the bezel away from the rear case.
  8. Now that you've freed the centers of the four sides, it's time to move on to the corners. Each corner is secured by two large clips that can't be freed by just pulling straight up like you did with the sides.
    • Now that you've freed the centers of the four sides, it's time to move on to the corners.
    • Each corner is secured by two large clips that can't be freed by just pulling straight up like you did with the sides.
    • In the next step, you'll be pushing in on the corner clip on the left of the bottom edge of the bezel.
    • Using a thin stiff prying device, like a Jimmy, press in against the bottom clip in the lower left corner (beneath the HDMI logo).
    • While pressing the clip in, pull up on the lower edge of the bezel. The entire corner should pop free.
  9. Once you've freed one corner, you should be able to gently twist the bezel off, freeing all of the remaining corners. If any corners are particularly stubborn, repeat the previous step on the difficult corner. If any corners are particularly stubborn, repeat the previous step on the difficult corner.
    • Once you've freed one corner, you should be able to gently twist the bezel off, freeing all of the remaining corners.
    • If any corners are particularly stubborn, repeat the previous step on the difficult corner.
  10. Remove the bezel.
    • Remove the bezel.
  11. Lift the LCD out of the rear case. The row of adjustment buttons will come out of the case with the display, attached by a thin ribbon cable. Take care not to damage the cable.
    • Lift the LCD out of the rear case.
    • The row of adjustment buttons will come out of the case with the display, attached by a thin ribbon cable. Take care not to damage the cable.
  12. With the casing removed, you now have access to the button board, cables, and the housing over the motherboard components.
    • With the casing removed, you now have access to the button board, cables, and the housing over the motherboard components.
12 autre(s) ont terminé cette réparation.
Sam Goldheart
Membre depuis le 18/10/2012
393 522 Réputation
545 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
108 membres
9 876 tutoriels rédigés
Do you know of any place that sell the replacement lcd screen?
treymcbrd - Réponse
Hi there, I have a little thunderbug trapped in the LCD is it possible to take the metal casing at the front of to reomve said bug? Thanks
TJ Grainger - Réponse
You could yes, but be very careful NOT to introduce dust into the panel!
Bertus van den Dikkenberg -
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 31
7 derniers jours : 198
30 derniers jours : 1,284
Total : 25,288
