Aller au contenu principal
ASUS VivoBook Flip TP501U WiFi Card Replacement
Ce dont vous avez besoin
  1. ASUS VivoBook Flip TP501U WiFi Card Replacement, Keyboard Panel: étape 1, image 1 de 2 ASUS VivoBook Flip TP501U WiFi Card Replacement, Keyboard Panel: étape 1, image 2 de 2
    • Open the laptop until it is flat and lay it screen down.
    • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
    • Remove two 4.8mm Phillips from the corners of the device.
  2. ASUS VivoBook Flip TP501U WiFi Card Replacement: étape 2, image 1 de 1
    • Turn the device face up.
    • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
    • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
  3. ASUS VivoBook Flip TP501U WiFi Card Replacement: étape 3, image 1 de 1
    • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
    • Remove the keyboard panel completely.
  4. ASUS VivoBook Flip TP501U WiFi Card Replacement, WiFi Card: étape 4, image 1 de 3 ASUS VivoBook Flip TP501U WiFi Card Replacement, WiFi Card: étape 4, image 2 de 3 ASUS VivoBook Flip TP501U WiFi Card Replacement, WiFi Card: étape 4, image 3 de 3
    • Locate and remove the single 3.17 mm screw holding in the WiFi card suing a Phillips #00 driver.
    • Disconnect the card from the motherboard by pulling down on the card.
    • Unplug the two black and white wires from the bottom of the card. They should pop off.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 761
