Aller au contenu principal
ASUS VivoBook S300C Hard Drive Replacement
Ce dont vous avez besoin
  1. ASUS VivoBook S300C Hard Drive Replacement, Remove the bottom cover: étape 1, image 1 de 1
    • Remove the 10 screws on the back cover.
    • Some screws are missing from this system. You should take your own notes to make sure you put the correct screws in during reassembly.
  2. ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive cable: étape 2, image 1 de 1
    • Remove the hard drive from the laptop. To do this, the cable is taped to the hard drive caddy. Remove the tape from the cable and disconnect the hard drive from the motherboard.
    • I am also missing screws here. Take your own notes to avoid misplacing screws during reassembly. They should all be the same length.
  3. ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive from the caddy: étape 3, image 1 de 2 ASUS VivoBook S300C Hard Drive Replacement, Remove the hard drive from the caddy: étape 3, image 2 de 2
    • Remove the 4 screws holding the hard drive in the caddy. There are two screws on each side.
    • Reassemble the laptop by following the steps in reverse order. This is my first guide, so let me know what I did wrong so I can fix it.
4 autres ont terminé cette réparation.
Cameron
Membre depuis le 12/02/15
10 365 Réputation
1 tutoriel rédigé
Équipe
Master Techs Membre de l'équipe Master Techs
Community
327 membres
1 697 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 14
Total : 3,605
