Aller au contenu principal
ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement, Wi-Fi Card: étape 1, image 1 de 1
    • Place the laptop upside down so that the bottom panel is facing upwards.
  2. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: étape 2, image 1 de 1
    • Unscrew the following 10 screws
    • Eight 5 mm Phillips head screws
    • Two 10 mm Phillips head screws
  3. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: étape 3, image 1 de 1
    • Carefully peel the panel off of the bottom of the laptop.
  4. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: étape 4, image 1 de 1
    • Remove the one 3 mm Phillips head screw holding the Wi-Fi card in place.
  5. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: étape 5, image 1 de 1
    • Carefully slide the card out of its connection port by pulling it outward.
  6. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: étape 6, image 1 de 1
    • Remove the black and white antenna cable connector wires by carefully pulling upwards on them.
    • Note that the black wire connects to "Main" and the white wire connects to "Aux".
Keith Rachels
Membre depuis le 03/04/16
595 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-4, Bhusal Spring 2016 Membre de l'équipe UMass Dartmouth, Team 3-4, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G4
2 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 527
