Aller au contenu principal
ASUS VivoBook S400C Hard Drive Replacement
Ce dont vous avez besoin
  1. ASUS VivoBook S400C Hard Drive Replacement, Remove the Bottom Cover: étape 1, image 1 de 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Hard Drive Replacement: étape 2, image 1 de 2 ASUS VivoBook S400C Hard Drive Replacement: étape 2, image 2 de 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Hard Drive Replacement, Disconnect the Battery: étape 3, image 1 de 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Hard Drive Replacement, Battery: étape 4, image 1 de 1
    • With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
  5. ASUS VivoBook S400C Hard Drive Replacement: étape 5, image 1 de 1
    • Carefully lift the battery up and out of the device.
  6. ASUS VivoBook S400C Hard Drive Replacement, Hard Drive: étape 6, image 1 de 1
    • Remove the three Phillips #0 screws holding the the hard drive in place:
    • Two 3.8 mm screws.
    • One 5.7 mm screw.
  7. ASUS VivoBook S400C Hard Drive Replacement: étape 7, image 1 de 1
    • Pull left and lift out the hard drive.
Tiana Curry
Membre depuis le 10/18/19
85 Réputation
1 tutoriel rédigé
Équipe
UC Santa Barbara, Team S4-G4, Bator Fall 2019 Membre de l'équipe UC Santa Barbara, Team S4-G4, Bator Fall 2019
UCSB-BATOR-F19S4G4
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 28
Total : 2,020
