Aller au contenu principal
ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement
Ce dont vous avez besoin
  1. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: étape 1, image 1 de 3 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: étape 1, image 2 de 3 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement, Hard Drive: étape 1, image 3 de 3
    • Flip the laptop onto its backside.
    • Use a Phillips #00 screwdriver to remove the nine 1.2 mm Phillips #00 screws screws attached to the laptop backing.
  2. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: étape 2, image 1 de 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: étape 2, image 2 de 2
    • Remove the laptop backing with a prying tool. Use the prying tool between the keyboard and bottom grooves.
    • Start prying from the center of the laptop and work your way around the edges of the laptop to remove the keyboard panel.
    • It is recommended to use a plastic prying tool versus a metal prying tool as it could scratch your laptop.
  3. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: étape 3, image 1 de 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: étape 3, image 2 de 2
    • Separate the laptop keyboard from the laptop backing.
    • Carefully remove the keyboard connector from the motherboard.
  4. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: étape 4, image 1 de 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: étape 4, image 2 de 2
    • Remove the two 3 mm screws attached to the laptop's hard drive metal cage using the Phillips #00 screwdriver.
    • Once the screws have been removed, gently disconnect the hard drive by pulling the hard drive away from the integrated SATA port.
  5. ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: étape 5, image 1 de 2 ASUS VivoBook X541UA-SB51-CB Hard Drive Replacement: étape 5, image 2 de 2
    • Remove the four 3 mm screws attached to hard drive metal cage using the Phillips #00 screwdriver.
    • Remove the hard drive from the bracket.
3 autres ont terminé cette réparation.
David Nguyen
Membre depuis le 05/14/21
202 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G18, Melo-Thaiss Summer 2021 Membre de l'équipe York University, Team S1-G18, Melo-Thaiss Summer 2021
YORK-MELO-THAISS-SU21S1G18
1 membre
1 tutoriel rédigé
Un commentaire
I replaced the original sata into a ssd but it doesnt boot to windows. It gets stuck in bios. The ssd has an os already. It appears in the storage section but not in the boot list. I have already tried to boot the ssd to my computer and it works.
Christusjohn Leoncio L Salvani - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 54
Total : 1,740
