Aller au contenu principal
ASUS VivoTab Note 8 Motherboard Replacement
Ce dont vous avez besoin
  1. ASUS VivoTab Note 8 Motherboard Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the pen and memory card if you have them; they may get in the way when you are opening the device.
    • Pry open the edges of the cover using the plastic opening tool. The memory card slot is very useful for getting started.
  2. ASUS VivoTab Note 8 Motherboard Replacement: étape 2, image 1 de 2 ASUS VivoTab Note 8 Motherboard Replacement: étape 2, image 2 de 2
    • Move the opening tool along the edges of the tablet and push up wherever you can. You may need to open up all of the sides to take the panel off.
    • Pull apart the sides of the casing by hand.
  3. ASUS VivoTab Note 8 Motherboard Replacement: étape 3, image 1 de 1
    • After pulling the panel off, put it to the side.
  4. ASUS VivoTab Note 8 Motherboard Replacement, Motherboard: étape 4, image 1 de 1
    • Unplug the battery from the motherboard.
    • Lodge something (a fingernail works fine) under the connecting piece and apply a force straight up and perpendicular to the back of the device.
  5. ASUS VivoTab Note 8 Motherboard Replacement: étape 5, image 1 de 1
    • Remove the screws from the black plastic restraint restricting the motherboard's movement using a Phillips #000 screwdriver.
    • Gently remove the black plastic restraint from the motherboard.
  6. ASUS VivoTab Note 8 Motherboard Replacement: étape 6, image 1 de 1
    • Remove the six screws holding the motherboard in place using a Phillips #000 screwdriver.
  7. ASUS VivoTab Note 8 Motherboard Replacement: étape 7, image 1 de 1
    • Gently pull out the remaining ribbons and cords still plugged into the motherboard.
    • Remove the motherboard from the device.
Ryan Spencer
Membre depuis le 09/21/18
753 Réputation
6 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 12
Total : 674
