Introduction
The fan is the most crucial part of the ASUS Vivobook Q301LA-BSI5T17. If the fan doesn’t work properly you will run a risk of overheating your laptop. Once a laptop overheats you can cause multiple internal problems.
These steps will help you replace your fan and prevent your laptop from overheating.
Ce dont vous avez besoin
Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
Presque terminé !
