Aller au contenu principal
ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement
Ce dont vous avez besoin
  1. ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
  2. ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: étape 2, image 1 de 2 ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: étape 2, image 2 de 2
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: étape 3, image 1 de 3 ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: étape 3, image 2 de 3 ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: étape 3, image 3 de 3
    • Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver.
    • Use the black plastic spudger to remove the battery from the device.
  4. ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: étape 4, image 1 de 3 ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: étape 4, image 2 de 3 ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement: étape 4, image 3 de 3
    • Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
  5. ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement, Hard Drive: étape 5, image 1 de 2 ASUS Vivobook Q301LA-BSI5T17 Hard Drive Replacement, Hard Drive: étape 5, image 2 de 2
    • Gently pull on the hard drive bay to disconnect it from the motherboard.
Jens Peter Andersen
Membre depuis le 10/03/17
658 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S5-G1, Walkup Fall 2017 Membre de l'équipe USF Tampa, Team S5-G1, Walkup Fall 2017
USFT-WALKUP-F17S5G1
4 membres
6 tutoriels rédigés
Un commentaire
Vorrei installare un secondo hdd al posto del lettore cd. Devo comprare un HDD Caddy, che ha ha il lettore cd? Con quali caratteristiche è comprensarlo? GRAZIE
Antonio Leanza - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 3,047
