Aller au contenu principal
ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement
Ce dont vous avez besoin
  1. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Back Case Housing: étape 1, image 1 de 1
    • Remove all ten 6mm Phillips #1 screws from the bottom of the computer chassis.
  2. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: étape 2, image 1 de 1
    • Carefully pry open the back cover from the laptop and place it to the side.
  3. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: étape 3, image 1 de 2 ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement, Memory Card: étape 3, image 2 de 2
    • Lift the perforated metal cover up from the motherboard to expose the memory cards.
  4. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: étape 4, image 1 de 2 ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: étape 4, image 2 de 2
    • Once the cover is removed the RAM will be accessible.
    • Use your fingertips to pry out the metal guards outlining both of the sides of the memory card.
    • The RAM stick should then pop up to rest at an angle to the motherboard.
  5. ASUS Vivobook Q301LA-BSI5T17 Memory Card Replacement: étape 5, image 1 de 1
    • Using your fingertips, slide the memory card out from the plastic housing and remove it from the board.
    • Be sure to remove the card at the same angle at which it rests to avoid damaging the card or the contacts of the slot.
Mark Fanelli
Membre depuis le 04/09/19
97 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G2, Hovde Spring 2019 Membre de l'équipe IUPUI, Team S1-G2, Hovde Spring 2019
IUPUI-HOVDE-S19S1G2
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 419
