Aller au contenu principal
ASUS Vivobook Q301LA-BSI5T17 RAM Replacement
Ce dont vous avez besoin
  1. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement, Battery: étape 1, image 1 de 1
    • Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
  2. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: étape 2, image 1 de 2 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: étape 2, image 2 de 2
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: étape 3, image 1 de 3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: étape 3, image 2 de 3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: étape 3, image 3 de 3
    • Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver.
    • Use the black plastic spudger to remove the battery from the device.
  4. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: étape 4, image 1 de 3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: étape 4, image 2 de 3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: étape 4, image 3 de 3
    • Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
  5. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement, RAM: étape 5, image 1 de 2 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement, RAM: étape 5, image 2 de 2
    • Gently pry this metal cover off the motherboard.
  6. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: étape 6, image 1 de 3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: étape 6, image 2 de 3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: étape 6, image 3 de 3
    • Now the RAM stick is exposed. Using two fingers, gently push the buttons to release the RAM stick
  7. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: étape 7, image 1 de 1
    • When you put in the new RAM, make sure to line up the connectors. Put the RAM in gently, as being rough with it can cause damage to the stick.
Jens Peter Andersen
Membre depuis le 10/03/17
658 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S5-G1, Walkup Fall 2017 Membre de l'équipe USF Tampa, Team S5-G1, Walkup Fall 2017
USFT-WALKUP-F17S5G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 12
30 derniers jours : 20
Total : 1,337
