Aller au contenu principal
ASUS Vivobook S500CA Battery Replacement
Ce dont vous avez besoin
  1. ASUS Vivobook S500CA Battery Replacement, Battery: étape 1, image 1 de 1
    • Turn the device over to where the back plate is facing up.
  2. ASUS Vivobook S500CA Battery Replacement: étape 2, image 1 de 1
    • Use a Philips Head PH1 screwdriver to remove 10 screws (3 1cm screws and 7 .5cm screws) around the perimeter of the back plate.
    • Place screws where they cannot be lost as they will be used to replace the back plate.
  3. ASUS Vivobook S500CA Battery Replacement: étape 3, image 1 de 1
    • Remove the back plate by lifting it straight up.
  4. ASUS Vivobook S500CA Battery Replacement: étape 4, image 1 de 1
    • Remove 9 (.5 cm) phillips screws around the edge of the battery.
  5. ASUS Vivobook S500CA Battery Replacement: étape 5, image 1 de 1
    • Lift up the battery to reveal the battery terminal.
  6. ASUS Vivobook S500CA Battery Replacement: étape 6, image 1 de 1
    • Unclip the battery terminal by prying straight up on the sides of the connector to release the clip.
Deric Huffman
Membre depuis le 01/17/17
101 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 14
Total : 6,041
