Aller au contenu principal
ASUS X42J Laptop Fan Replacement
Ce dont vous avez besoin
  1. ASUS X42J Laptop Fan Replacement, Keyboard: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    Metal Spudger
    $2.99
    J'achète
    • Make sure your device is unplugged and turned off before proceeding.
    • Using a Spudger, gently pry up the keyboard.
  2. ASUS X42J Laptop Fan Replacement: étape 2, image 1 de 2 ASUS X42J Laptop Fan Replacement: étape 2, image 2 de 2
    Nylon Tipped Tweezers
    J'achète
    • Rotate the keyboard to face downward.
    • Pull out the blue wiring connection. Use tweezers to make it easier to remove.
  3. ASUS X42J Laptop Fan Replacement, Disk Drive: étape 3, image 1 de 1
    • Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
  4. ASUS X42J Laptop Fan Replacement: étape 4, image 1 de 1
    • Slide the disk drive out of the device.
  5. ASUS X42J Laptop Fan Replacement, Motherboard: étape 5, image 1 de 3 ASUS X42J Laptop Fan Replacement, Motherboard: étape 5, image 2 de 3 ASUS X42J Laptop Fan Replacement, Motherboard: étape 5, image 3 de 3
    • Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive.
  6. ASUS X42J Laptop Fan Replacement: étape 6, image 1 de 2 ASUS X42J Laptop Fan Replacement: étape 6, image 2 de 2
    • Rotate the laptop until it is sitting face up and extract all screws exposed by removing the keyboard.
  7. ASUS X42J Laptop Fan Replacement: étape 7, image 1 de 2 ASUS X42J Laptop Fan Replacement: étape 7, image 2 de 2
    Metal Spudger
    $2.99
    J'achète
    • Pull up on the front panel using the spudger until the front panel separates from the bottom panel.
  8. ASUS X42J Laptop Fan Replacement: étape 8, image 1 de 1
    • Unscrew and remove the marked screws.
  9. ASUS X42J Laptop Fan Replacement: étape 9, image 1 de 1
    • Separate the connectors.
  10. ASUS X42J Laptop Fan Replacement: étape 10, image 1 de 2 ASUS X42J Laptop Fan Replacement: étape 10, image 2 de 2
    • Remove the motherboard from the device.
  11. ASUS X42J Laptop Fan Replacement, Fan: étape 11, image 1 de 1
    • Unscrew the six screws using the Phillips #0 Screwdriver.
  12. ASUS X42J Laptop Fan Replacement: étape 12, image 1 de 1
    • Unplug the fan's wires from the motherboard.
  13. ASUS X42J Laptop Fan Replacement: étape 13, image 1 de 2 ASUS X42J Laptop Fan Replacement: étape 13, image 2 de 2
    • Remove the fan from the motherboard.
Ryan Pritchard
Membre depuis le 09/21/18
105 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
First step is wrong; attempting to prise out the keyboard will damage it. First step should be to remove the screws which hold in the keyboard.
Kate Gregory - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 13
Total : 571
