Aller au contenu principal
ASUS X44H-BBR4 Keyboard Replacement
Ce dont vous avez besoin
  1. ASUS X44H-BBR4 Keyboard Replacement, Keyboard: étape 1, image 1 de 2 ASUS X44H-BBR4 Keyboard Replacement, Keyboard: étape 1, image 2 de 2
    • Open the laptop to show the keyboard.
  2. ASUS X44H-BBR4 Keyboard Replacement: étape 2, image 1 de 1
    • Look at the top row of the keyboard, you will see a space that has four latches holding the keyboard down.
    • The latches are located above the Esc key, the F5 key, between the F10 and F11 key and the Delete key.
  3. ASUS X44H-BBR4 Keyboard Replacement: étape 3, image 1 de 3 ASUS X44H-BBR4 Keyboard Replacement: étape 3, image 2 de 3 ASUS X44H-BBR4 Keyboard Replacement: étape 3, image 3 de 3
    • Don't pull too hard on the keys otherwise they may fall off.
    • Push the latch away from the keyboard using the spudger point.
    • While pushing the latches use a plastic opening tool and pull up on a key near it.
    • Continue along the rest of the keyboard until it is released at all four latches.
  4. ASUS X44H-BBR4 Keyboard Replacement: étape 4, image 1 de 2 ASUS X44H-BBR4 Keyboard Replacement: étape 4, image 2 de 2
    • Push the keyboard away from the mouse track pad to unlock the bottom from the base.
    • Do not pull too hard because there is a ribbon connecting to keyboard to the motherboard.
  5. ASUS X44H-BBR4 Keyboard Replacement: étape 5, image 1 de 2 ASUS X44H-BBR4 Keyboard Replacement: étape 5, image 2 de 2
    • Flip the keyboard over to reveal the back of it and what is underneath.
  6. ASUS X44H-BBR4 Keyboard Replacement: étape 6, image 1 de 3 ASUS X44H-BBR4 Keyboard Replacement: étape 6, image 2 de 3 ASUS X44H-BBR4 Keyboard Replacement: étape 6, image 3 de 3
    • Pull each end of the black ribbon cable piece towards the mouse track pad to unlock the ribbon connector piece.
    • Gently pull out the ribbon cable from the connector piece.
  7. ASUS X44H-BBR4 Keyboard Replacement: étape 7, image 1 de 1
    • Remove the keyboard completely.
4 autres ont terminé cette réparation.
Kelly Merlo
Membre depuis le 10/14/15
500 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-3, Catania Fall 2015 Membre de l'équipe UMass Dartmouth, Team 4-3, Catania Fall 2015
UMASSD-CATANIA-F15S4G3
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 14
Total : 1,175
