Aller au contenu principal
ASUS X44H-BBR4 MotherBoard Replacement
Ce dont vous avez besoin
  1. ASUS X44H-BBR4 MotherBoard Replacement, Battery: étape 1, image 1 de 2 ASUS X44H-BBR4 MotherBoard Replacement, Battery: étape 1, image 2 de 2
    • Flip the device over.
  2. ASUS X44H-BBR4 MotherBoard Replacement: étape 2, image 1 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 2, image 2 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 2, image 3 de 3
    • Slide the right lock button to the unlock position.
    • After it is unlocked, a red line will be visible.
  3. ASUS X44H-BBR4 MotherBoard Replacement: étape 3, image 1 de 2 ASUS X44H-BBR4 MotherBoard Replacement: étape 3, image 2 de 2
    • Slide the left lock button into the unlock position and hold.
  4. ASUS X44H-BBR4 MotherBoard Replacement: étape 4, image 1 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 4, image 2 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 4, image 3 de 3
    • While holding the left lock button in the unlock position, push the battery from the center away from you.
  5. ASUS X44H-BBR4 MotherBoard Replacement, Keyboard: étape 5, image 1 de 2 ASUS X44H-BBR4 MotherBoard Replacement, Keyboard: étape 5, image 2 de 2
    • Open the laptop to show the keyboard.
  6. ASUS X44H-BBR4 MotherBoard Replacement: étape 6, image 1 de 1
    • Look at the top row of the keyboard, you will see a space that has four latches holding the keyboard down.
    • The latches are located above the Esc key, the F5 key, between the F10 and F11 key and the Delete key.
  7. ASUS X44H-BBR4 MotherBoard Replacement: étape 7, image 1 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 7, image 2 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 7, image 3 de 3
    • Don't pull too hard on the keys otherwise they may fall off.
    • Push the latch away from the keyboard using the spudger point.
    • While pushing the latches use a plastic opening tool and pull up on a key near it.
    • Continue along the rest of the keyboard until it is released at all four latches.
  8. ASUS X44H-BBR4 MotherBoard Replacement: étape 8, image 1 de 2 ASUS X44H-BBR4 MotherBoard Replacement: étape 8, image 2 de 2
    • Push the keyboard away from the mouse track pad to unlock the bottom from the base.
    • Do not pull too hard because there is a ribbon connecting to keyboard to the motherboard.
  9. ASUS X44H-BBR4 MotherBoard Replacement: étape 9, image 1 de 2 ASUS X44H-BBR4 MotherBoard Replacement: étape 9, image 2 de 2
    • Flip the keyboard over to reveal the back of it and what is underneath.
  10. ASUS X44H-BBR4 MotherBoard Replacement: étape 10, image 1 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 10, image 2 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 10, image 3 de 3
    • Pull each end of the black ribbon cable piece towards the mouse track pad to unlock the ribbon connector piece.
    • Gently pull out the ribbon cable from the connector piece.
  11. ASUS X44H-BBR4 MotherBoard Replacement: étape 11, image 1 de 1
    • Remove the keyboard completely.
  12. ASUS X44H-BBR4 MotherBoard Replacement, Hard Drive: étape 12, image 1 de 2 ASUS X44H-BBR4 MotherBoard Replacement, Hard Drive: étape 12, image 2 de 2
    • Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
  13. ASUS X44H-BBR4 MotherBoard Replacement: étape 13, image 1 de 2 ASUS X44H-BBR4 MotherBoard Replacement: étape 13, image 2 de 2
    • Once the screws are removed, slide the back panel away from the computer.
  14. ASUS X44H-BBR4 MotherBoard Replacement: étape 14, image 1 de 1
    • Remove the 9mm Phillips head screw in the left bottom corner of the hard drive with the PH0 bit.
  15. ASUS X44H-BBR4 MotherBoard Replacement: étape 15, image 1 de 2 ASUS X44H-BBR4 MotherBoard Replacement: étape 15, image 2 de 2
    • Slide the hard drive to the left, unlocking it from its default position.
  16. ASUS X44H-BBR4 MotherBoard Replacement: étape 16, image 1 de 2 ASUS X44H-BBR4 MotherBoard Replacement: étape 16, image 2 de 2
    • Pull the hard drive upwards and take it out of its position.
  17. ASUS X44H-BBR4 MotherBoard Replacement: étape 17, image 1 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 17, image 2 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 17, image 3 de 3
    • Remove two 3mm Phillips head screws, one located on each side of the metal casing holding the hard drive using the PH0 bit.
  18. ASUS X44H-BBR4 MotherBoard Replacement: étape 18, image 1 de 1
    • Pull upwards on the metal casing and it will come off.
  19. ASUS X44H-BBR4 MotherBoard Replacement, Front Panel: étape 19, image 1 de 3 ASUS X44H-BBR4 MotherBoard Replacement, Front Panel: étape 19, image 2 de 3 ASUS X44H-BBR4 MotherBoard Replacement, Front Panel: étape 19, image 3 de 3
    • Lift up the black lock holding the ribbon.
    • Using the blue tab, pull out the ribbon.
    • Pull gently on the ribbon to remove the risk of damaging the ribbon.
  20. ASUS X44H-BBR4 MotherBoard Replacement: étape 20, image 1 de 1
  21. ASUS X44H-BBR4 MotherBoard Replacement: étape 21, image 1 de 2 ASUS X44H-BBR4 MotherBoard Replacement: étape 21, image 2 de 2
    • Remove the five 9 mm Phillips head screws with the PH0 bit.
  22. ASUS X44H-BBR4 MotherBoard Replacement: étape 22, image 1 de 2 ASUS X44H-BBR4 MotherBoard Replacement: étape 22, image 2 de 2
    • Flip the laptop on its side so that the red line indicated in the pictures is facing upwards.
  23. ASUS X44H-BBR4 MotherBoard Replacement: étape 23, image 1 de 2 ASUS X44H-BBR4 MotherBoard Replacement: étape 23, image 2 de 2
    • Pull up on the disk drive and remove.
  24. ASUS X44H-BBR4 MotherBoard Replacement: étape 24, image 1 de 2 ASUS X44H-BBR4 MotherBoard Replacement: étape 24, image 2 de 2
    • Close the laptop and flip it over.
    • Remove the six 12.5 mm screws Phillips head and the five 9 mm screws remaining with the PH0 bit.
  25. ASUS X44H-BBR4 MotherBoard Replacement: étape 25, image 1 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 25, image 2 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 25, image 3 de 3
    • Flip the device back over and open the laptop.
    • Using the nylon or metal spudger, gently pry off the panel by moving the spudger along the seam.
    • You should hear clicking sounds as the front panel is being removed from the base.
  26. ASUS X44H-BBR4 MotherBoard Replacement: étape 26, image 1 de 1
    • Remove the panel.
    • The laptop will now become heavier to the front so it will tend to fall on the back side of the screen.
  27. ASUS X44H-BBR4 MotherBoard Replacement, MotherBoard: étape 27, image 1 de 2 ASUS X44H-BBR4 MotherBoard Replacement, MotherBoard: étape 27, image 2 de 2
    • Remove the 5mm Phillips head screw using the PH0 bit.
  28. ASUS X44H-BBR4 MotherBoard Replacement: étape 28, image 1 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 28, image 2 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 28, image 3 de 3
    • Pull up on the tape holding the tan cable in place.
    • While holding the tape push up on each side of the cable connector to disconnect it.
  29. ASUS X44H-BBR4 MotherBoard Replacement: étape 29, image 1 de 1
    • Gently pull out the cable connector.
  30. ASUS X44H-BBR4 MotherBoard Replacement: étape 30, image 1 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 30, image 2 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 30, image 3 de 3
    • Gently pull out the USB connector attached to the motherboard.
  31. ASUS X44H-BBR4 MotherBoard Replacement: étape 31, image 1 de 2 ASUS X44H-BBR4 MotherBoard Replacement: étape 31, image 2 de 2
    • Remove the red and white wire connector next to the fan.
  32. ASUS X44H-BBR4 MotherBoard Replacement: étape 32, image 1 de 1
    • Take out the motherboard
    • There are still two wires connected to the bottom of the motherboard so remove carefully.
  33. ASUS X44H-BBR4 MotherBoard Replacement: étape 33, image 1 de 1
    • Flip the motherboard over next to the laptop base.
  34. ASUS X44H-BBR4 MotherBoard Replacement: étape 34, image 1 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 34, image 2 de 3 ASUS X44H-BBR4 MotherBoard Replacement: étape 34, image 3 de 3
    • Remove the white and black wire.
    • The motherboard is not completely separated from the base of the computer.
3 autres ont terminé cette réparation.
Devaj Ramsamooj
Membre depuis le 10/21/15
824 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-3, Catania Fall 2015 Membre de l'équipe UMass Dartmouth, Team 4-3, Catania Fall 2015
UMASSD-CATANIA-F15S4G3
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 9
Total : 2,007
