Aller au contenu principal
Pour réparer ensemble - Je crée un compte
ASUS X502CA Battery Replacement
Ce dont vous avez besoin
  1. ASUS X502CA Battery Replacement, Palm Rest with Keyboard and Touch Pad: étape 1, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Battery Replacement: étape 2, image 1 de 1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Battery Replacement: étape 3, image 1 de 2 ASUS X502CA Battery Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Battery Replacement: étape 4, image 1 de 2 ASUS X502CA Battery Replacement: étape 4, image 2 de 2
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA Battery Replacement, Battery: étape 5, image 1 de 1
    • Next, locate the battery in the front of laptop (closest to you).
  6. ASUS X502CA Battery Replacement: étape 6, image 1 de 1
    • Unplug the battery from the laptop in the upper right hand corner of the battery using tweezers.
    • If battery is not unplugged, motherboard may shock you.
  7. ASUS X502CA Battery Replacement: étape 7, image 1 de 2 ASUS X502CA Battery Replacement: étape 7, image 2 de 2
    • Use the Phillips #00 Screwdriver to carefully remove the 6 screws holding the battery in place.
    • Once you have removed all six screws carefully lift the battery out and dispose.
    • Each screw is 50 mm in length and 15 mm in diameter.
5 autres ont terminé cette réparation.
David Conner
Membre depuis le 03/03/15
292 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 14-1, Shirley Winter 2015 Membre de l'équipe Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 membres
5 tutoriels rédigés
1 commentaire de tutoriel
Thank you for posting this
SteveFFFFF 0 - Réponse Partager
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 22
30 derniers jours : 62
Total : 15,119
