Aller au contenu principal
ASUS X502CA Left I/O Board Replacement
Ce dont vous avez besoin
  1. ASUS X502CA Left I/O Board Replacement, Palm Rest with Keyboard and Touch Pad: étape 1, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Left I/O Board Replacement: étape 2, image 1 de 1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Left I/O Board Replacement: étape 3, image 1 de 2 ASUS X502CA Left I/O Board Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Left I/O Board Replacement: étape 4, image 1 de 2 ASUS X502CA Left I/O Board Replacement: étape 4, image 2 de 2
    • Lift Palm Rest away.
    • Replace with new palm rest.
  5. ASUS X502CA Left I/O Board Replacement, Left I/O Board: étape 5, image 1 de 2 ASUS X502CA Left I/O Board Replacement, Left I/O Board: étape 5, image 2 de 2
    • Locate the I/O board on the left of the computer. Using the Phillips #0 screwdriver, unscrew the three 5mm screws to unhinge the screen, which will free the board allowing it to be removed and replaced.
    • Be careful with handling your computer while one side is unhinged; mishandling or over pressuring the other hinge could cause damage to it or the screen.
  6. ASUS X502CA Left I/O Board Replacement: étape 6, image 1 de 2 ASUS X502CA Left I/O Board Replacement: étape 6, image 2 de 2
    • Unplug the power strip connecting to the motherboard with your fingers or plastic opening tool.
    • Make sure the power strip is disconnected before pulling the board out.
  7. ASUS X502CA Left I/O Board Replacement: étape 7, image 1 de 2 ASUS X502CA Left I/O Board Replacement: étape 7, image 2 de 2
    • Slightly pull the unhinged screen up to free the board and remove it.
Christian Spencer
Membre depuis le 11/06/18
436 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018 Membre de l'équipe UMass Dartmouth, Team S5-G6, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G6
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 199
