Aller au contenu principal
ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement
Ce dont vous avez besoin
  1. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement, Palm Rest with Keyboard and Touch Pad: étape 1, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: étape 2, image 1 de 1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: étape 3, image 1 de 2 ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: étape 3, image 2 de 2
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: étape 4, image 1 de 2 ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: étape 4, image 2 de 2
    • Lift Palm Rest away.
    • Replace with new palm rest.
5 autres ont terminé cette réparation.
Michael Morrow
Membre depuis le 03/03/15
258 Réputation
1 tutoriel rédigé
Équipe
Clemson, Team 14-1, Shirley Winter 2015 Membre de l'équipe Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 membres
5 tutoriels rédigés
Un commentaire
there is no reason to disassemble the top-half of the laptop.
seanwilson684 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 8
Total : 1,904
