Aller au contenu principal
ASUS X533SA-BHCLN10 Battery Replacement
Ce dont vous avez besoin
  1. ASUS X533SA-BHCLN10 Battery Replacement, Battery: étape 1, image 1 de 2 ASUS X533SA-BHCLN10 Battery Replacement, Battery: étape 1, image 2 de 2
    • Turn over the laptop on the back panel.
    • Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
  2. ASUS X533SA-BHCLN10 Battery Replacement: étape 2, image 1 de 2 ASUS X533SA-BHCLN10 Battery Replacement: étape 2, image 2 de 2
    • Turn over the laptop with the keyboard facing upwards.
    • Using a small prying or opening tool, stick the prying tool under the edge of the laptop.
  3. ASUS X533SA-BHCLN10 Battery Replacement: étape 3, image 1 de 2 ASUS X533SA-BHCLN10 Battery Replacement: étape 3, image 2 de 2
    • After the laptop is completely pried open carefully remove the keyboard from the laptop.
    • There are two small keyboard cables connecting the keyboard to the laptop. Carefully remove these by popping up the white clips holding them in place and slide the connector out.
3 autres ont terminé cette réparation.
Edmund Lee
Membre depuis le 09/26/17
473 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S13-G3, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S13-G3, Boczar Fall 2017
USFT-BOCZAR-F17S13G3
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 656
