Aller au contenu principal
ASUS X533SA-BHCLN10 Hard Drive Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. ASUS X533SA-BHCLN10 Hard Drive Replacement, Battery: étape 1, image 1 de 2 ASUS X533SA-BHCLN10 Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Turn over the laptop on the back panel.
    • Use the Phillips #0 screwdriver to unscrew all ten screws visible on the back panel. There should be a total of ten screws: (4) four 5.5mm screws and (6) six 10.5mm screws.
  2. ASUS X533SA-BHCLN10 Hard Drive Replacement: étape 2, image 1 de 2 ASUS X533SA-BHCLN10 Hard Drive Replacement: étape 2, image 2 de 2
    • Turn over the laptop with the keyboard facing upwards.
    • Using a small prying or opening tool, stick the prying tool under the edge of the laptop.
  3. ASUS X533SA-BHCLN10 Hard Drive Replacement: étape 3, image 1 de 2 ASUS X533SA-BHCLN10 Hard Drive Replacement: étape 3, image 2 de 2
    • After the laptop is completely pried open carefully remove the keyboard from the laptop.
    • There are two small keyboard cables connecting the keyboard to the laptop. Carefully remove these by popping up the white clips holding them in place and slide the connector out.
  4. ASUS X533SA-BHCLN10 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 3 ASUS X533SA-BHCLN10 Hard Drive Replacement, Hard Drive: étape 4, image 2 de 3 ASUS X533SA-BHCLN10 Hard Drive Replacement, Hard Drive: étape 4, image 3 de 3
    • The hard drive is closest to the screen, enclosed in a metal plate.
    • Remove all screws holding the hard drive in place.
  5. ASUS X533SA-BHCLN10 Hard Drive Replacement: étape 5, image 1 de 1
    • After all screws are removed, carefully disconnect the hard drive and slide it out.
  6. ASUS X533SA-BHCLN10 Hard Drive Replacement: étape 6, image 1 de 1
    • Remove screws from the metal plate enclosing hard drive and enclose replacement hard drive in metal plate.
Anthony Bristow
Membre depuis le 09/28/17
116 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S13-G3, Boczar Fall 2017 Membre de l'équipe USF Tampa, Team S13-G3, Boczar Fall 2017
USFT-BOCZAR-F17S13G3
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 12
Total : 486
