Aller au contenu principal
ASUS X550LB-DS71 Motherboard Replacement
Ce dont vous avez besoin
  1. ASUS X550LB-DS71 Motherboard Replacement, Motherboard: étape 1, image 1 de 3 ASUS X550LB-DS71 Motherboard Replacement, Motherboard: étape 1, image 2 de 3 ASUS X550LB-DS71 Motherboard Replacement, Motherboard: étape 1, image 3 de 3
    • Make sure to switch off your laptop before starting.
    • Place the laptop on a flat surface with the bottom side facing upwards.
    • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
    • Using both hands, slide the back panel away from the laptop horizontally.
  2. ASUS X550LB-DS71 Motherboard Replacement: étape 2, image 1 de 1
    • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
    • At this point, it is advised to disconnect the hard drive from the motherboard.
  3. ASUS X550LB-DS71 Motherboard Replacement: étape 3, image 1 de 3 ASUS X550LB-DS71 Motherboard Replacement: étape 3, image 2 de 3 ASUS X550LB-DS71 Motherboard Replacement: étape 3, image 3 de 3
    • Using the plastic opening tool, open the back cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  4. ASUS X550LB-DS71 Motherboard Replacement: étape 4, image 1 de 2 ASUS X550LB-DS71 Motherboard Replacement: étape 4, image 2 de 2
    • Locate the three ribbon connectors.
    • Using the plastic opening tool, flip up all three gray tabs and remove the ribbon connectors from the motherboard.
    • Once the tabs are released, the ribbons will be easy to remove. Do not pull on the ribbons.
  5. ASUS X550LB-DS71 Motherboard Replacement: étape 5, image 1 de 2 ASUS X550LB-DS71 Motherboard Replacement: étape 5, image 2 de 2
    • Locate the gold ribbon connecting the motherboard to the display.
    • Lift up the tape and disconnect the ribbon.
  6. ASUS X550LB-DS71 Motherboard Replacement: étape 6, image 1 de 2 ASUS X550LB-DS71 Motherboard Replacement: étape 6, image 2 de 2
    • Using the Phillips #0 Screwdriver, remove the nine 2mm screws at the marked locations.
  7. ASUS X550LB-DS71 Motherboard Replacement: étape 7, image 1 de 2 ASUS X550LB-DS71 Motherboard Replacement: étape 7, image 2 de 2
    • Disconnect the WLAN Card from the motherboard by pulling the connector upwards.
    • Disconnect the optical drive from the motherboard by sliding it to the right.
  8. ASUS X550LB-DS71 Motherboard Replacement: étape 8, image 1 de 3 ASUS X550LB-DS71 Motherboard Replacement: étape 8, image 2 de 3 ASUS X550LB-DS71 Motherboard Replacement: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Flip the motherboard to show the underside.
    • Locate the two square connections attached to the motherboard.
    • Disconnect them using blunt tweezers.
  9. ASUS X550LB-DS71 Motherboard Replacement: étape 9, image 1 de 3 ASUS X550LB-DS71 Motherboard Replacement: étape 9, image 2 de 3 ASUS X550LB-DS71 Motherboard Replacement: étape 9, image 3 de 3
    • Using the Phillips #0 Screwdriver, remove the seven 2mm screws at the marked locations.
    • Remove the heat sink from the motherboard.
3 autres ont terminé cette réparation.
Nathan Dyer
Membre depuis le 09/25/17
550 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S16-G1, Eyestone Fall 2017 Membre de l'équipe USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 22
Total : 2,012
