Aller au contenu principal
ASUS X552LAV-BBI5N08 CD Drive Replacement
Ce dont vous avez besoin
  1. ASUS X552LAV-BBI5N08 CD Drive Replacement, Battery: étape 1, image 1 de 1
    • Battery is not showed in pictures.
    • Flip the laptop face down.
  2. ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 2, image 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 2, image 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 2, image 3 de 3
    • Slide the right button to the left.
    • Hold the left button to the right.
    • While you hold the left button in position, slide the battery out by pushing it away from you.
  3. ASUS X552LAV-BBI5N08 CD Drive Replacement, CD Drive: étape 3, image 1 de 1
    • Locate the bottom panel. It is at the opposite end of the battery.
    • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
  4. ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 4, image 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 4, image 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 4, image 3 de 3
    • Remove bottom panel by lifting it up.
    • Locate the hard drive.
    • It is located in the bottom left corner.
  5. ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 5, image 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 5, image 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 5, image 3 de 3
    • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
    • Slide the hard drive out to the left.
  6. ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 6, image 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 6, image 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 6, image 3 de 3
    • Use Tri-wing Y1 screwdriver to remove seven 4mm screws from battery area.
    • Use opening tool to split keyboard from base of the laptop.
    • Make sure to start from one end and go around the edges.
  7. ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 7, image 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 7, image 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 7, image 3 de 3
    • Flip laptop to sit on its bottom.
    • Lift keyboard up by the front edge
  8. ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 8, image 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 8, image 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 8, image 3 de 3
    • Flip up the small locking flap for the two ZIF connectors.
    • Unplug the connectors that are keeping the keyboard connected.
  9. ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 9, image 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 9, image 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 9, image 3 de 3
    • Flip up the locking flap for the ZIF connector.
    • Unplug the connector that is keeping the keyboard connected.
  10. ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 10, image 1 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 10, image 2 de 3 ASUS X552LAV-BBI5N08 CD Drive Replacement: étape 10, image 3 de 3
    • Remove keyboard from laptop.
    • Remove two 4mm screws around CD drive
    • Slide the CD drive out to the right to remove it.
Jason Vo
Membre depuis le 02/15/18
857 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S17-G1, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S17-G1, Boczar Spring 2018
USFT-BOCZAR-S18S17G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 233
