Aller au contenu principal
ASUS X552LAV-BBI5N08 Hard Drive Replacement
Ce dont vous avez besoin
  1. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Battery is not showed in pictures.
    • Flip the laptop face down.
  2. ASUS X552LAV-BBI5N08 Hard Drive Replacement: étape 2, image 1 de 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: étape 2, image 2 de 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: étape 2, image 3 de 3
    • Slide the right button to the left.
    • Hold the left button to the right.
    • While you hold the left button in position, slide the battery out by pushing it away from you.
  3. ASUS X552LAV-BBI5N08 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • Start by flipping the laptop face down.
    • Locate the bottom panel. It is at the opposite end of the battery.
    • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
  4. ASUS X552LAV-BBI5N08 Hard Drive Replacement: étape 4, image 1 de 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: étape 4, image 2 de 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: étape 4, image 3 de 3
    • Remove bottom panel by lifting it up.
    • Locate the hard drive.
    • It is located in the bottom left corner.
  5. ASUS X552LAV-BBI5N08 Hard Drive Replacement: étape 5, image 1 de 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: étape 5, image 2 de 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: étape 5, image 3 de 3
    • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
    • Slide the hard drive out to the left.
  6. ASUS X552LAV-BBI5N08 Hard Drive Replacement: étape 6, image 1 de 2 ASUS X552LAV-BBI5N08 Hard Drive Replacement: étape 6, image 2 de 2
    • Lift the hard drive out.
    • Once the hard drive is removed, place the hard drive at a different area.
  7. ASUS X552LAV-BBI5N08 Hard Drive Replacement: étape 7, image 1 de 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: étape 7, image 2 de 3 ASUS X552LAV-BBI5N08 Hard Drive Replacement: étape 7, image 3 de 3
    • Place the hard drive on its side.
    • Remove the four 5mm screws from the sides of the case by using a Tri-wing Y1 screwdriver.
    • Lift the hard drive out of the case.
Jason Vo
Membre depuis le 02/15/18
857 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S17-G1, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S17-G1, Boczar Spring 2018
USFT-BOCZAR-S18S17G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 12
Total : 297
