Aller au contenu principal
ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement
Ce dont vous avez besoin
  1. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Back Cover: étape 1, image 1 de 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Back Cover: étape 1, image 2 de 2
    • Flip the laptop over so the model stickers face the ceiling.
  2. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: étape 2, image 1 de 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: étape 2, image 2 de 2
    • Remove eleven 7mm Phillips #00 screws that secure the back cover.
    • Two screws are under the rubber pad.
  3. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: étape 3, image 1 de 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: étape 3, image 2 de 2
    • Using a spudger, carefully remove the back cover.
  4. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Battery: étape 4, image 1 de 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Battery: étape 4, image 2 de 2
    • Remove the six 3mm Phillips #00 screws holding the battery in place.
  5. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: étape 5, image 1 de 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: étape 5, image 2 de 2
    • Disconnect the battery wires from the motherboard by pulling on the black tab using a spudger or your hands.
  6. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: étape 6, image 1 de 1
    • Carefully lift the battery up and out of the laptop.
  7. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: étape 7, image 1 de 3 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: étape 7, image 2 de 3 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: étape 7, image 3 de 3
    • Remove four 3 mm Phillips screws (two on each side) holding the hard drive in the frame
  8. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: étape 8, image 1 de 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: étape 8, image 2 de 2
    • Grip the side of the hard drive and slide it out of the device.
Joshua Letizia
Membre depuis le 10/30/19
193 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S4-G4, Saloman Fall 2019 Membre de l'équipe UMass Dartmouth, Team S4-G4, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G4
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 8
Total : 550
