Aller au contenu principal
ASUS ZenPad S 8.0 Daughter Board Replacement
Ce dont vous avez besoin
  1. ASUS ZenPad S 8.0 Daughter Board Replacement, Rear Cover Removal: étape 1, image 1 de 3 ASUS ZenPad S 8.0 Daughter Board Replacement, Rear Cover Removal: étape 1, image 2 de 3 ASUS ZenPad S 8.0 Daughter Board Replacement, Rear Cover Removal: étape 1, image 3 de 3
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Daughter Board Replacement: étape 2, image 1 de 2 ASUS ZenPad S 8.0 Daughter Board Replacement: étape 2, image 2 de 2
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Daughter Board Replacement: étape 3, image 1 de 3 ASUS ZenPad S 8.0 Daughter Board Replacement: étape 3, image 2 de 3 ASUS ZenPad S 8.0 Daughter Board Replacement: étape 3, image 3 de 3
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Daughter Board Replacement: étape 4, image 1 de 2 ASUS ZenPad S 8.0 Daughter Board Replacement: étape 4, image 2 de 2
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Daughter Board Replacement, Daughter Board: étape 5, image 1 de 3 ASUS ZenPad S 8.0 Daughter Board Replacement, Daughter Board: étape 5, image 2 de 3 ASUS ZenPad S 8.0 Daughter Board Replacement, Daughter Board: étape 5, image 3 de 3
    • To remove the ribbon cables, lift up the white retaining flap on the ZIF Connectors with a plastic pry tool
  6. ASUS ZenPad S 8.0 Daughter Board Replacement: étape 6, image 1 de 3 ASUS ZenPad S 8.0 Daughter Board Replacement: étape 6, image 2 de 3 ASUS ZenPad S 8.0 Daughter Board Replacement: étape 6, image 3 de 3
    • Using the tweezers gently pull off the tape over the ribbon cable
  7. ASUS ZenPad S 8.0 Daughter Board Replacement: étape 7, image 1 de 2 ASUS ZenPad S 8.0 Daughter Board Replacement: étape 7, image 2 de 2
    • Using the tweezers gently pull the ribbon cable out from from the connector.
  8. ASUS ZenPad S 8.0 Daughter Board Replacement: étape 8, image 1 de 3 ASUS ZenPad S 8.0 Daughter Board Replacement: étape 8, image 2 de 3 ASUS ZenPad S 8.0 Daughter Board Replacement: étape 8, image 3 de 3
    • Using the tweezers gently remove the connector from the yellow slot
  9. ASUS ZenPad S 8.0 Daughter Board Replacement: étape 9, image 1 de 2 ASUS ZenPad S 8.0 Daughter Board Replacement: étape 9, image 2 de 2
    • Cut the warranty tape connecting the daughter board to the metal plate under the battery
  10. ASUS ZenPad S 8.0 Daughter Board Replacement: étape 10, image 1 de 3 ASUS ZenPad S 8.0 Daughter Board Replacement: étape 10, image 2 de 3 ASUS ZenPad S 8.0 Daughter Board Replacement: étape 10, image 3 de 3
    • Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the daughter board
    • Gently lift the daughter board from the device
5 autres ont terminé cette réparation.
John Astfanous
Membre depuis le 10/04/16
987 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 2-2, Cagle Fall 2016 Membre de l'équipe USF Tampa, Team 2-2, Cagle Fall 2016
USFT-CAGLE-F16S2G2
4 membres
5 tutoriels rédigés
4 commentaires
Thanks for helping me fix my beloved Zenpad!
Karen Detter - Réponse
Karen, where did you get the replacement daughter board? I can’t find one anywhere! - Christine
Christine Collister -
Bought it here:
https://www.asusparts.eu/en/Asus-90NP01M...
This is Part Number: 32YU1CB0000,
“ASUSparts” internal part number: 90NP01M0-R10010
4andrew - Réponse
Please clarify Step 9 - where exactly is the warranty tape that needs to be cut?
I have this unit and it stopped charging and stopped holding charge- I do not want to buy another unit as I invested a LOT of time in setting this one up…
Thanks
vshulyaker@gmail.com
Vladimir Shulyaker - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 24
Total : 3,727
