Aller au contenu principal
ASUS ZenPad S 8.0 Front Facing Camera Replacement
Ce dont vous avez besoin
  1. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: étape 1, image 1 de 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: étape 1, image 2 de 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Rear Cover Removal: étape 1, image 3 de 3
    • if present, remove the MicroSD card before disassembly. Failure to remove could lead to damage to the MicroSD card , rear cover, or MicroSD card slot.
    • Use the plastic tool to pry between the silver bezel and the back case
    • Work the tool around the device to free the back case
  2. ASUS ZenPad S 8.0 Front Facing Camera Replacement: étape 2, image 1 de 2 ASUS ZenPad S 8.0 Front Facing Camera Replacement: étape 2, image 2 de 2
    • Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
    • Do not kink the ribbon cables as they can break easily
  3. ASUS ZenPad S 8.0 Front Facing Camera Replacement: étape 3, image 1 de 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement: étape 3, image 2 de 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement: étape 3, image 3 de 3
    • Remove the battery connector by prying it up away from the device using 2 plastic pry tools
  4. ASUS ZenPad S 8.0 Front Facing Camera Replacement: étape 4, image 1 de 2 ASUS ZenPad S 8.0 Front Facing Camera Replacement: étape 4, image 2 de 2
    • Remove all 9 of the 1.5mm #00 Philips screws
    • Gently lift the battery out of the device
    • Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
  5. ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: étape 5, image 1 de 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: étape 5, image 2 de 3 ASUS ZenPad S 8.0 Front Facing Camera Replacement, Front Facing Camera: étape 5, image 3 de 3
    • Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
  6. ASUS ZenPad S 8.0 Front Facing Camera Replacement: étape 6, image 1 de 1
    • Use a tweezers to lift out the camera
    • If you lifted the latch for the ribbon cable then it should come out with little resistance.
John Astfanous
Membre depuis le 10/04/16
987 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 2-2, Cagle Fall 2016 Membre de l'équipe USF Tampa, Team 2-2, Cagle Fall 2016
USFT-CAGLE-F16S2G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 4
Total : 1,333
