Introduction
This guide will help you remove the back cover of your device in two easy steps. This guide is the first step for removing and replacing any internal part of your device. For this process, you will need only one tool, which is specified in this guide. By following the steps, the back cover removal should only take 1-2 minutes of your time and will cause no damage to your device.
Ce dont vous avez besoin
To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
