Aller au contenu principal
AUX-208P1 Electric Kettle Temperature Controller Replacement
Ce dont vous avez besoin
  1. AUX-208P1 Electric Kettle Temperature Controller Replacement, Temperature Controller: étape 1, image 1 de 2 AUX-208P1 Electric Kettle Temperature Controller Replacement, Temperature Controller: étape 1, image 2 de 2
    • Clean all the dirt on the bottom of the electric kettle.
  2. AUX-208P1 Electric Kettle Temperature Controller Replacement: étape 2, image 1 de 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: étape 2, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the three 19 mm screws at the bottom of the electric kettle.
    • Remove the base of the electric kettle.
    • Remove the LED indicator buckled on the base.
  3. AUX-208P1 Electric Kettle Temperature Controller Replacement: étape 3, image 1 de 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: étape 3, image 2 de 2
    • Use combination pliers to clamp the connection between the electric kettle line and the old temperature controller to create a gap, and pull it off.
    • Don't use too much force to avoid damage to the line!
  4. AUX-208P1 Electric Kettle Temperature Controller Replacement: étape 4, image 1 de 1
    • Use combination pliers to remove the nuts holding down the old temperature controller.
  5. AUX-208P1 Electric Kettle Temperature Controller Replacement: étape 5, image 1 de 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: étape 5, image 2 de 2
    • Remove the broken temperature controller.
    • Clean the bottom of the kettle to remove any dust or debris buildup.
  6. AUX-208P1 Electric Kettle Temperature Controller Replacement: étape 6, image 1 de 1
    • Align the socket on the bottom of the new temperature controller with the protrusion on the bottom of the electric kettle to assemble.
  7. AUX-208P1 Electric Kettle Temperature Controller Replacement: étape 7, image 1 de 1
    • Use combination pliers to reinstall the nuts holding down the temperature controller.
  8. AUX-208P1 Electric Kettle Temperature Controller Replacement: étape 8, image 1 de 1
    • Fasten the electric kettle circuit to the contact reed of the new temperature controller.
    • Gently pull the interface to ensure a firm installation.
  9. AUX-208P1 Electric Kettle Temperature Controller Replacement: étape 9, image 1 de 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: étape 9, image 2 de 2
    • Re-buckle the removed LED indicator back to the base.
    • Buckle the base back to the bottom of the electric kettle.
    • Use a Phillips #0 screwdriver to three 19 mm screws on the bottom of the kettle.
重新组装设备时,请依次相反的拆卸顺序。
SHAN HUANG
Membre depuis le 01/13/21
193 Réputation
2 tutoriels rédigés
Équipe
York University, Team S1-G30, O'Regan Winter 2021 Membre de l'équipe York University, Team S1-G30, O'Regan Winter 2021
YORK-O'REGAN-W21S1G30
1 membre
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 22
30 derniers jours : 54
Total : 1,840
