Aller au contenu principal
AYL SoundFit Battery Replacement
Ce dont vous avez besoin
  1. AYL SoundFit Battery Replacement, Battery: étape 1, image 1 de 1
    • Remove the four hex screws on the top of the device using a 2.5 hex screwdriver.
  2. AYL SoundFit Battery Replacement: étape 2, image 1 de 1
    • Place a spudger between the black plastic cover and the green case.
    • Pry the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Battery Replacement: étape 3, image 1 de 1
    • Place a spudger between the black housing, which contains the woofer, and the outer rubber casing.
    • Pry the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Battery Replacement: étape 4, image 1 de 2 AYL SoundFit Battery Replacement: étape 4, image 2 de 2
    • Remove the two Phillips #00 screws securing the battery casing.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Battery Replacement: étape 5, image 1 de 1
    • Desolder the positive and negative battery contacts from the motherboard.
    • Remove the battery from the device.
Dustin Moore
Membre depuis le 02/16/16
108 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 3-3, Harley Spring 2016 Membre de l'équipe IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 membres
5 tutoriels rédigés
4 commentaires
Which battery is this, and what is the mAH?
jlongsa - Réponse
3.7V 1500mAh, 5.55Wh
Coba Farr -
The charger works but it does not say chargeing
Zaira Cortes - Réponse
18650 battery
rich4349 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 29
Total : 2,746
